I'm bringing my rear wheel to a local indy to have a new tire put on. \\; Should I remove both the rear belt drive sprocket and brake disks or can the new tire be put on the rim with these in place? \\;
I've only had dealers do this for me in the past but indy will do the work for only 30 bucks so I'm all in for getting this done on my own.
Thanks,
D
Just remove wheel from bike and take it in. \\; \\; You'll want the rotor &\\; pulley on when it gets balanced.
Enjoy the 1/2hr labor you saved too \\;  \\; \\; \\; \\; \\; Way to go !
Thanks notlost,
I hadn't even thought about the impact they would have to the balancing of the wheel if they weren't there....duh.
Ride safe,
D
My dealer could not balance my rear wheel with the IDS on it. They had to remove the large outside part with the rubber and bearing in it to balance it. It does run very smooth at any speed anyway.
I changed my own rear tire and went the dynabeads route. Didn't work quite so well for me. I tried them for a few months before the vibration got to me and I ended up taking it all off and had the dealership clean out the beads and remount and balance for me. I think I paid about $35. I took the money I saved and ordered a pair of floating rotors. So in the end, I guess the moco got my hard earned cash deposited in their wallets anyway. )
