burning oil ?
Old Jul 20, 2008 | 09:48 PM
83shovelhead's Avatar
83shovelhead
6th Gear
Default burning oil ?
I have got a 05 roadking with only 10 k miles and i have to add a quart every 1000 miles.Anyone else encounter this ? Some say the 05 have skinnier valves.Input ?
Old Jul 20, 2008 | 10:12 PM
TXCHOP's Avatar
TXCHOP
Default RE: burning oil ?
Get your valve stem seals changed to the new viton style and the problem will dissapear!
Old Jul 21, 2008 | 07:25 AM
rags's Avatar
rags
There was a problem with a lot of the 05s with valve guide seals. Mine used 1 quart per 1500 miles. All of it going through the rear cylinder. My rear spark plug would be carboned up to the point of almost being fouled. Front plug would be nice and clean. The problem can be on&nbsp\\;front, rear, or &nbsp\\;both cylinders, but most often on rear only. I had new valve guide seals installed by Indy on rear cylinder,cost $240, 10,000 miles later no oil consumption. Early on Harley would not warranty. Said this&nbsp\\;amount of oil consumption was normal. Later on more dealers were replacing under warranty. &nbsp\\;
Old Jul 23, 2008 | 05:32 AM
bdeuce's Avatar
bdeuce
I am also using a quart every 1500 miles but my plugs are clean could I have another issue other than vavle seals.05 eglide /ness big sucker/ jetted carb/ wildpigs slip ons
Old Jul 23, 2008 | 07:15 AM
FastHoss's Avatar
FastHoss
Valve seals,mine did it at 24,500,easy fix,the heads don't have to come off.&nbsp\\;
Old Jul 23, 2008 | 09:11 AM
Ugly Troll's Avatar
Ugly Troll
ORIGINAL: FastHoss
Valve seals,mine did it at 24,500,easy fix,the heads don't have to come off.&nbsp\\;\\\\\\;
Hoss, can you give a little more detail? I have an 05 EGC, and I'm being told I have bad seals (front plug only fouling), that the company knew about it, they will not cover it, and it's going to cost at least $600 to fix. If it's not that big a deal, I'll just do it myself. Thanks
Troll
Old Jul 23, 2008 | 09:48 AM
FastHoss's Avatar
FastHoss
Hey Troll it cost me 320.00 at the Harley dealer,they used a fitting in the plug hole for air to hold up the valve,took off valve covers put on seals,they could have warrantyed it but said the compression was too even,tried to get them to do it ,but oh well.
chubbygator
May 19, 2011 01:19 PM
DMcBiker
Sep 14, 2009 02:47 PM
pokeraddict
Oct 17, 2008 11:59 AM
O5HOG
Exhaust System Topics
Sep 25, 2006 03:20 PM
gsparesa
Jun 13, 2006 12:20 AM
