newbie question
Old Jul 25, 2008 | 12:59 PM
08UC's Avatar
08UC
Default newbie question
going to try and do my own tire changes. the service manual says to raise the rear wheel high enough to remove the axle. how much higher can i expect to lift it to remove the wheel and tire?
thanks,
bob
2008 ultra classic w/ abs all stock
edit: do you guys remove the brake disc as well or can this all be done with that intact?
Old Jul 25, 2008 | 01:02 PM
garyhendley's Avatar
garyhendley
Default RE: newbie question
you have to lift it off the ground do you have a bead breaker and balancer ??
ride safe
Old Jul 25, 2008 | 01:04 PM
bigskyhd's Avatar
bigskyhd
Really ought to have a bike jack or center stand to do this.&nbsp\\; Sears has a fair jack for bikes at less tha $100.
Old Jul 25, 2008 | 01:11 PM
blueflht's Avatar
blueflht
needs to be approx 3 ft off the ground. high enough to clear fender. then lay on ground with 2x4 uner rim 2x4 on top of rim by bead. drive car on board till bead breaks. then use spoons to remove. lots of lube!
Old Jul 25, 2008 | 01:19 PM
rocknrod's Avatar
rocknrod
If this is your first time be carefull when you remove the weight from the rear wheel. Balance accordingly.
Old Jul 25, 2008 | 01:29 PM
rocknrod's Avatar
rocknrod
The reason I say that is after I removed my rear tire I went to the front. The sissor jack is powdercoated and so is the frame. No rubber. Left off the weight of the front tire and the bike started sliding rearward away from me. Talk about tightening&nbsp\\; up your grommet
Old Jul 25, 2008 | 06:07 PM
08UC's Avatar
08UC
argh
it wont let me reply
i have tried about ten times to reply..thank you all
i don't get it
i am planning on getting the h.f. set up along with the mojo lever.
i have a center stand and a lift
thank you master chief for your service and words of wisdom
kryingame
Jan 4, 2017 11:46 AM
foxtrapper
Jan 12, 2013 07:32 PM
CT-Bagger
Dec 8, 2011 05:42 PM
Djstorm100
Mar 13, 2008 08:39 AM
reeac
Sep 5, 2007 10:34 AM
