starting issue electra glide
Old Jul 31, 2008 | 03:11 PM
abate1's Avatar
abate1
Default starting issue electra glide
Need some help - I have a 2007 Electra Glide Classic, K&amp\\;\\\\\\;N air filter, Rinehart true duals, Power Commander. When starting it is slow to kick off (Yes I know how the PC gets it's power) and most times it kicks back or pops and throws a rear cyl. no compression code. The bike has been on the dyno and runs 13.2-13.5 as straight as an arrow throught out the throttle settings. The bike started great with no issues prior to the Power Commander. Any fixes or suggestions? Thanks - Doc
Old Jul 31, 2008 | 03:16 PM
TexasRedneck's Avatar
TexasRedneck
Default RE: starting issue electra glide
First thang ah'd check is the battery/electrical all the way ta the starter...
Old Jul 31, 2008 | 04:55 PM
rickoshay45's Avatar
rickoshay45
Some of the older PC's had a problem with starting. If you are turning on the ignition and waiting for the check engine lite to go out, try turning it on and starting right away. It may help.
Old Jul 31, 2008 | 04:56 PM
patsac's Avatar
patsac
try this ...hit the starter button befor the fuel pump stops running
nss
General Topics/Tech Tips
38
Jun 30, 2017 11:05 AM
abate1
Welcome Area Only
Jul 30, 2008 09:44 PM
98glide
Jul 15, 2008 01:14 AM
carlosgtn
Jan 10, 2008 06:17 PM
wildside41
Aug 29, 2006 09:37 PM
