Front Break Lever
Old Aug 1, 2008 | 08:05 AM
rambo11's Avatar
rambo11
Default Front Break Lever
I just noticed that my front break lever seems to be loose causing my brake lites to stay on or flicker. Is there some sort of adjustment?
Thanks
Jim
Old Aug 1, 2008 | 09:06 AM
rockdoc's Avatar
rockdoc
Default RE: Front Break Lever
Bud of mine had the same problem....his entire hand control unit had to be replaced. The small plunger on the master cylinder had issues and was the culprit.
Old Aug 1, 2008 | 09:20 AM
dawg's Avatar
dawg
Try 45072-96C $36.50 first.&nbsp\\; That's a rebuild kit with plunger and all for the 07
Old Aug 1, 2008 | 09:27 AM
Pumba11's Avatar
Pumba11
I had the same problem and just had to replace the light switdh inside the unit.
Old Aug 1, 2008 | 10:53 AM
bagman1's Avatar
bagman1
Is there not a plastic anti rattle clip like on the clutch lever? If so this is probably the cause, most likely a 99 cent part.
Old Aug 1, 2008 | 12:15 PM
rambo11's Avatar
rambo11
Didnt notice a plastic clip. I'll check it out tonight. Thanks
Old Aug 1, 2008 | 02:05 PM
bagman1's Avatar
bagman1
Just checked my parts book. No clip but maybe the bushing may be worn. Or the switch itself.
Old Aug 1, 2008 | 06:16 PM
FXSTDSE2's Avatar
FXSTDSE2
I found the weather seal failing and the plunger sticking. dawg gave the part #. been about a year, no problems since. Nice kit, comes with everything.
b bop n bob
Sep 28, 2017 11:41 PM
HDMarkyB
Wheels/Tires
11
Aug 9, 2012 05:19 AM
JC650
Jul 2, 2011 03:47 PM
Beercan321
Jun 3, 2011 06:48 PM
hockey8787
Apr 8, 2008 07:15 PM
