pulling ecu codes 96 road king
Old Aug 1, 2008 | 11:53 PM
monstermustang's Avatar
monstermustang
Stage IV
Default pulling ecu codes 96 road king
the procedure in my manual does not seem to work on my bike. anyone know the correct procedure for pulling codes on a 96 road king?
thanks
Old Aug 6, 2008 | 11:42 PM
monstermustang
Stage IV
anyone?
Old Aug 7, 2008 | 12:45 AM
hawghead88's Avatar
hawghead88
5th Gear
Try This: &nbsp\\; on my 1998 road king classic with fuel inj. you can read the codes doing the following:
1-turn ignition key switch to ignition and then turn off 1 second after fuel pump stops.
2.repeat #1 again..remember 1 second after pump stops
3.turn ignition key switch to ignition and wait about 8 seconds for a bunch of flashing of the check engine light
it will then stop for 2 seconds..get ready... these are the codes you must count:
it will slowly flash 1,2,3,5....there is NO 4....this is the first digit of the 2 digit code ..so it can only be 1,2,3,5 &nbsp\\; __ __
then a 2 second pause...then you will get second digit of the 2 digit code..it can only be 1,2,3,4,5,6
remember after the complete 2 digit code is given you will go back to the rapid flash sequence..
there are a total of 15 codes available with this procedure
examples
52,53,54,55 bad news ECM replacement
56 crank/cam sensor
11 throttle sensor
12 barometric
23 and 32 are injectors front/rear
24 coil
33 fuel pump relayin this case you would not hear the pump but instead waited 3 seconds after the on / off sequence
in order to erase any codes you must disconnect the battery or wait for 50 on and off riding cycles
ieatchickens
EVO
14
Aug 28, 2018 10:17 PM
phat96
EVO
14
Dec 25, 2009 09:18 AM
bigstevex4
Jun 30, 2008 12:40 PM
Biker Trash
Apr 10, 2008 05:52 AM
eg1997
Aug 26, 2007 05:45 PM
