keeping bike cooler
Old Aug 2, 2008 | 12:09 PM
papifun's Avatar
papifun
Default keeping bike cooler
i have a late 2008 SG- i heard i can deactivate rear cylinder getting fuel to keep leg cooler when it is at a light..EITMS (Engine Idle Temperature Management System) , manual says nothing how to do it. i read has sometihing to do with the cruise control and throttle position and then color of cruise control lamp... does it make that much of a differance ??
Old Aug 2, 2008 | 12:16 PM
Glyde's Avatar
Glyde
Default RE: keeping bike cooler
Roll the throttle forward for 3 sec when at idle to enable or disable. Cruise control light will blink green for enabled, yellow for disabled. Ride safe.
Old Aug 2, 2008 | 02:44 PM
Yachtman's Avatar
Yachtman
Is that really going to make a diiference at a stoplight?&nbsp\\; The heads and exhaust will still&nbsp\\; be cookin, so how much cooler can it be for a minute or so?
Old Aug 2, 2008 | 03:27 PM
Dionicio's Avatar
Dionicio
It works for me. It's better than nothing.
Old Aug 2, 2008 | 03:39 PM
shekmark's Avatar
shekmark
My 08 shut down on me Friday, in traffic, cause it got so hot. Dealer said it supposed to.
Old Aug 2, 2008 | 03:46 PM
Dionicio's Avatar
Dionicio
First time I heard That. Did the Dealer tell You at what temp the engine must be at when it shuts down?
Old Aug 2, 2008 | 04:36 PM
jag1886's Avatar
jag1886
&nbsp\\;You should do a stage one upgrade and get a set of RJ Originals, shutting off the back cylinder is a bandage.&nbsp\\;
Old Aug 2, 2008 | 06:33 PM
Glyde's Avatar
Glyde
It made a little difference for me. I installed Kuryakyn saddle shields and those helped considerably more.
Installing a high flow AC, exhaust and proper tuning will make a major difference.
Old Aug 2, 2008 | 08:43 PM
Weavr99FLHT's Avatar
Weavr99FLHT
ORIGINAL: papifun
&nbsp\\;
Page 140 of 2008 touring owners manual.
Old Aug 2, 2008 | 09:37 PM
Suede Blue Man's Avatar
Suede Blue Man
Treating the symptoms is like some kind of crazy voodoo. I think curing the problem is the key, upgrade to a more freely exhaling exhaust and the stage one kit along with the SERT/SEST. Oil cooler if necessary. Making the engine run cooler is the key. I did all but the oil cooler and actually made a world of difference on mine.
