Neutral switch
Old Aug 4, 2008 | 06:40 AM
rookiedan's Avatar
rookiedan
Default Neutral switch
On my 05 EG I have problems getting my neutral light to come on. Anyone have any similar problems and is there any cure?
Old Aug 4, 2008 | 06:51 AM
newrench's Avatar
newrench
Default RE: Neutral switch
unplug the two wires from the neutral switch itself (on tranny cover), run a jumper wire from one to the other.
If the light comes on without any problems there is a real good chance&nbsp\\; the switch (part# 33904-00)&nbsp\\;needs to be replaced.
Old Aug 4, 2008 | 07:05 AM
Skulmn's Avatar
Skulmn
They are on the third revision of the switch....It is $18.&nbsp\\; Replace it.&nbsp\\; Very simple to get to and there is NO adjustment on the switch.&nbsp\\; It seems that they fail when they get hot.&nbsp\\; I'll be that when your bike "cools" it will work again.&nbsp\\;
&nbsp\\;
But as new wrench said, first check that power is going to the two plugs on the switch.
&nbsp\\;
Simply replace it... I did on my '07 and had NO further problem.
Old Aug 4, 2008 | 08:06 AM
pokeraddict's Avatar
pokeraddict
I had the same problem with my 05 a few months ago. I pulled the wires off, squeezed the connectors a slight amount, sprayed contact cleaner on the connections and replaced the wires. It has been working ever since.
Old Dec 31, 2008 | 08:37 PM
Airpump's Avatar
Airpump
rookiedan,
Did you locate your problem??? I am having the same problem with my 06 EG.
Old Mar 16, 2015 | 03:01 PM
UltraBlueharley07's Avatar
UltraBlueharley07
1st Gear
I've been having issues with my 2007 Ultra Glide not cranking after the bike gets hot, my Neutral like will flicker after riding awhile,I had searched this forum about this issue but other problems were mentioned, I think you have hit the nail on the head for my issue, I just wish I had found this thread earlier, I've switched out everything else , spent around $400.00 and now it might be a $12 part. I'll have to check this out, thanks for your information this really helps!
Old Jul 29, 2015 | 04:07 PM
Muleears's Avatar
Muleears
There's a seller on eBay selling Neutral Switches for $9 shipped. Genuine Harley parts. I'm not affiliated, just thought someone else could benefit. I did!
http://www.ebay.com/itm/141723346536...%3AMEBIDX%3AIT
HDmikie
Jan 7, 2012 07:20 PM
grumpy56
Dec 27, 2010 07:29 PM
Worped
Mar 23, 2010 11:36 PM
oldhippie
Nov 4, 2009 08:24 PM
schienbein
Aug 27, 2009 01:59 PM
