Neutral Light not working
Old Dec 8, 2011 | 08:16 PM
HDmikie's Avatar
HDmikie
Default Neutral Light not working
My 2002 Fatboy just got here a week ago and I love it. The only thing I noticed was that the neutral light doesn't work. Anybody have any idea how to fix it or what to check? Thanks!
Old Dec 8, 2011 | 08:41 PM
Eric Moore's Avatar
Eric Moore
I'd start with the neutral switch on top of the tranny...it could be unhooked or a broken wire...
Old Dec 8, 2011 | 09:31 PM
Aborigen2's Avatar
Aborigen2
On the tranny cover is the Neutral Gear Switch, looks like a hex nut with two terminals.
-Remove the terminals from the switch (just pull them up)
- Turn Ign ON
- with paper clip short both terminals of the switch - if the green "N" comes up, then the problem is in the switch.
a.) Switch problem:
- Make sure the tranny is in Neutral (rock the bike to verify)
- Connect back the terminals, turn Ignition ON
- try to tighten up the switch with an open wrentch (within 1/4 of a turn the "N" should light up if the switch is lose)
- If the "N" doesnt light up- you'll need to replace the switch.
b) Wiring problem ("N" Doesn't light up when the terminals are shorted)
- could be a broken wire at the Indicator Bar (at the connectors), inspect wiring at the Indicator bar
- could be a burnt "N" light.
In any case the most probable causes are:
- unhooked switch terminal (inspect and reconnect)
- unseated switch ( need to be tighten up no more than 1/4 of a turn)
Good luck!
Old Dec 9, 2011 | 04:46 AM
RHillbilly's Avatar
RHillbilly
Could be bulb in dash just replaced mine
Old Dec 9, 2011 | 08:27 AM
HDmikie's Avatar
HDmikie
Thanks guys! How hard is it to get to the bulb?
Whups.......double post. Maybe moderator can remove this one.
Old Dec 9, 2011 | 08:28 AM
HDmikie's Avatar
HDmikie
Old Jan 7, 2012 | 07:20 PM
HDmikie's Avatar
HDmikie
Just fixed the problem. Was at the Harley dealer today and a mechanic was in the parts area. I asked him and he said to buy a new Neutral Switch for $14. Well, the mechanic was right. It was a little tough swapping out the switch, but I finally got it done and now green light works. YAY!
petewood70
EVO
15
Jun 19, 2020 05:08 PM
Dazzauk
EVO
May 9, 2016 02:36 PM
BACADon
Oct 30, 2015 04:47 PM
Thomo_Baca
15
Jan 8, 2012 12:24 AM
badgerland
Aug 6, 2008 08:36 PM
