Neutral Light
Old Dec 24, 2010 | 06:12 PM
grumpy56's Avatar
grumpy56
Default Neutral Light
Another of those infamous '06 Dyna issues. Have had the nuetral light come on intermittently (when its not supposed to) ever since my scoot was new. 7600 miles. However, today it stayed on and would not go off. Any ideas o how to troubleshoot/fix this annoyance? Thanks.
Old Dec 24, 2010 | 06:42 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Not that familar with the 06's but on the earlier Dynas the neutral light switch is on top of the transmission cover. It will have two push on wires, check those wires for corrosion and security . You want to also pull the switch and clean the little ball with a degreaser then reinstall the switch.
Old Dec 24, 2010 | 07:39 PM
jaxdwg's Avatar
jaxdwg
what he said. the connections may be loose or the switch contact may have given up
Old Dec 24, 2010 | 09:45 PM
grumpy56's Avatar
grumpy56
Thank you both. Will pull the switch and clean the contacts and the ball on the bottom.
Old Dec 25, 2010 | 08:42 AM
mike634's Avatar
mike634
Had the same problem with my 06. The switch was bad and had to be replaced.
Old Dec 25, 2010 | 09:27 AM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
I'm not sure if its a similar issue or not but sometimes when I shift gears on my 2010 fatbob the 6th gear light will come on briefly when letting the clutch in or out. I've gotten all required maintenance done at harley during the 15,000 miles i've put on it and no mechanic has said anything but I'm curious.
Old Dec 27, 2010 | 07:29 PM
grumpy56's Avatar
grumpy56
Was just checking access to that nuetral switch. I wonder how you get a wrench on it without wiping out the finish on your tranny cover? It looks like I might be able to get a breaker bar/ratchet on it if I remove the battery tray. Anyone try that? Gracias.
Dazzauk
EVO
May 9, 2016 02:36 PM
falconbrother
EVO
Oct 3, 2014 03:26 AM
Thomo_Baca
15
Jan 8, 2012 12:24 AM
HDmikie
Jan 7, 2012 07:20 PM
badgerland
Aug 6, 2008 08:36 PM
