Bike jack
Old Aug 4, 2008 | 11:47 AM
rookiedan's Avatar
rookiedan
Default Bike jack
Just picked up a cycle jack for my EG. When the bike's on it's stand leaning towards the left is there anything I need to know in order to start the lift? a little nervous on picking the bike off the ground when it's tilted. Thanks everyone and ride on!
Old Aug 4, 2008 | 12:30 PM
garyhendley's Avatar
garyhendley
Default RE: Bike jack
when you are raising the jack the bike should be centered on the jack so it lifts
&nbsp\\;
the tires evenly off the ground-ride safe
Old Aug 4, 2008 | 12:38 PM
FXSTDSE2's Avatar
FXSTDSE2
Center on my Ultra is rear arm about 1 inch from the rear of the frame. I sit on the bike and pump it with my right foot until it sits stable. The spread is perfect for all the oils but that also depends on what jack you have.
Old Aug 5, 2008 | 04:42 AM
Bad Pig's Avatar
Bad Pig
mine i go in from the right side, left arm of the jack is&nbsp\\;under the rear crossmember on the frame, i have to pull the bike towards me off its side stand to get the jack under it all the way (bike is lowered) and jack it up, its what works for me.
Old Aug 5, 2008 | 04:53 AM
Bossman1's Avatar
Bossman1
[sm=ttiwwp.gif]
What kind of jack??
Old Aug 5, 2008 | 04:55 AM
Bad Pig's Avatar
Bad Pig
i have the harbor freight yellow jack. cheap but it does what i need it to do.
Old Aug 5, 2008 | 06:16 AM
campincowboy's Avatar
campincowboy
You didn't say whay jack you have, but mine is big red from northern, and lifts the same way. I have done frt, rear tire changes, fork replace, exhaust...list goes on, with no issues. Bike straightens up the higher I go.
Old Aug 5, 2008 | 06:45 AM
bdp's Avatar
bdp
Item 02792, Harbor Freight $60 on sale a few months ago.
Old Aug 5, 2008 | 04:43 PM
joelin5386's Avatar
joelin5386
I use the Sears Craftsman jack and it scares the crap out of me. My front tire is about 3 to 4 inches off the ground before my rear tire starts to go up. Am I doing something wrong
Old Aug 6, 2008 | 09:56 PM
20RDKING04's Avatar
20RDKING04
I also have the sears yellow jack...works fine but would buy a better one next time. really unstable..for me..don't trust..
