Is there anyone that knows if there are finaly some ABS brake line extensions available for the 08 road kings, so a guy can put on a set of 14 inch wild 1 ape hangers.
After countless searches I have found everything else that I would need, including the NAMZ wire extensions for both the trottle by wire and all the other electrical in the bars, as well as the clutch cable.
any help would be great.
Also a big thanx to all on the forum that have already helped out.
I have managed to work up the courage to give this a go, even with the dealer scare tacktics.
Up here in Alberta Canada they want $2000 - $2500 for the bar swap, I think that is just a little steep.
Thanx again
Would like to know also, if anyone has installed an extended upper ABS brake line with or without issues. Any special procedures to know about, such as re-calibration/Digital Tech,, ect..
