What Amp?
Old Aug 7, 2008 | 01:48 PM
Crusher's Avatar
Crusher
Default What Amp?
Besides Hog Tunes or Hawg Wired. Anyone use a different 2 channel amp? If so, what. Need one for my 2008 SG.
Old Aug 7, 2008 | 02:45 PM
blueflht's Avatar
blueflht
arc audio mini amp is a high quality amp. around 350$. blaupunkt pa2100 if you can find 1 mhaudio mini amp also nice. remember higher wattage amps require speakers which may be hard to find in a 5.25 size. i went with jl audio componets
Old Aug 7, 2008 | 02:50 PM
txcomp's Avatar
txcomp
I'm using an amp from SAS (Southern Audio Services) otherwise known as Bazooka. It's 4 channel but comes with a plug and play harness.
Old Aug 7, 2008 | 03:02 PM
1Reaper's Avatar
1Reaper
Are these 2 ohm amps so they wont hurt the speakers, I have J and M speakers and would like to run a small amp to improve volume, with my 08 street glide.
Old Aug 7, 2008 | 03:13 PM
txcomp's Avatar
txcomp
The Bazooka is 4 Ohm I believe. I replaced all 4 speakers when I did the amp and they were all 2 Ohm speakers that I pulled out and 4 Ohms that I put back in.
Old Aug 7, 2008 | 03:16 PM
blueflht's Avatar
blueflht
sup don! if you use a blaupunkt it will run 2 or 4 ohms in 2 channel mode. most amps will run 2 or 4 ohm speakers. thye advantage to 2 ohms is the amp can run more power with less power draw. downside is limited speakers choice in 2 ohm configuration
Old Aug 7, 2008 | 03:23 PM
blueflht's Avatar
blueflht
here you go guys. this should fit in fairing. check metric measurements to be sure 1reaper look how this amp can run in 2 or 4 ohm setup
Old Aug 7, 2008 | 03:27 PM
1Reaper's Avatar
1Reaper
Sup blueflht, do we know each other?
And what size amp should I run with a stock Harmon/Kardon deck and J&M speakers?
Old Aug 7, 2008 | 03:31 PM
1Reaper's Avatar
1Reaper
There is no link to the amp?
blueflht's Avatar
blueflht
don you should be sending me a sample of your awesome paint!! need to keep the amp under 100 watts per channel for j&m heres another sample from ebay. http://cgi.ebay.com/ebaymotors/Bazoo...QQcmdZViewItem
