I’ve had the H-D bag lid covers installed on my ’07 SG for some time. Well, as you may know, it gets hotter that h*ll here in So Kali. The adhesive that comes with the covers to hold the Velcro on is become pliable/gooey and is not holding
So – can someone recommend and industrial type (?) of adhesive that will hold in high temperatures?
3M double sided tape that they use to attach moldings, etc to cars. It will be a bitch to remove later on but it will stick good.
It is VHB and it does work very well if applied correctly. make sure you clean the spot with Goo Gone or similar and then isopropyl, let that dry good and apply. You'll have to chisel it off!
