Windshield Vibration
Old Aug 12, 2008 | 05:32 PM
Yogibear's Avatar
Yogibear
It's an "easy" fix. You can buy the new brackets from the stealer
or if you have a friend with a welder you could fix the old one or solder
a piece of metal to the bracket itself.
Figures HD would use the cheapest/lightest metal on the face of the earth
for a part like this. Maybe the metric bikes got it right by using bamboo!
Dennis
2003 FLHTCI
Old Aug 12, 2008 | 05:55 PM
garyhendley's Avatar
garyhendley
read about the fairing brackets breaking alot on this forum on the eg's
ride safe
Old Aug 12, 2008 | 06:05 PM
Wassup8687's Avatar
Wassup8687
Do dealers cover this under warranty?
Old Aug 12, 2008 | 06:06 PM
84 softy's Avatar
84 softy
them little brass inserts that the winshield screws screw into can come loose also.. Epoxy works good when this happens.
Old Aug 12, 2008 | 08:38 PM
hitone's Avatar
hitone
Just started doing the same on my 2007 FLHX after 20,000 miles. Took off outer fairing and nothing was broken or cracked or loose. Will check motor mounts but not sure what to look for with them. Anyone know?
Old Aug 13, 2008 | 11:20 PM
Born2Glide's Avatar
Born2Glide
I was told that with the motor running you should be able to fit a business card between the rubber and the metal at the top of the mount but I am not really sure. Mine was obvious that something was wrong.
I fixed those damn brass inserts until I could not get the epoxy to hold them any more, I think it was because my motor mount was collapsed. I finally got some brass inserts for wood that has really course threads on the outside, heated them up really good and screwed/melted them into place, so far it has worked like a charm. I have a new mount on order.
Old Aug 27, 2008 | 08:35 PM
SteveM's Avatar
SteveM
I have 17K miles on my 07 Ultra and over the last couple days noticed a little more vibration than "normal" on the right side. After reading all the posts about broken brackets I decided to see for myself.
Sure enough. The right bracket is broken at the bend as everyone has described. So, I'm off to my dealer on Friday to have it repaired under warranty.
Thanks to all for the great information on this forum.
leftyjm
2014-2024 Touring Models
Aug 17, 2016 06:22 PM
viperpit07
Aug 21, 2014 12:59 PM
myred55
Sep 8, 2009 08:15 AM
JC650
Jul 17, 2007 12:36 AM
SteelCityScooter
May 24, 2007 11:55 AM
