Cruise control
Old Aug 13, 2008 | 02:52 PM
mrtnz03's Avatar
mrtnz03
1st Gear
Default Cruise control
Well this is my first posting since registering with the forum. I just bought cruise control for my 2006 Street Glide and was wondering if the installation is something I could do myself? The description H-D gives makes it sound like it's a pretty simple procedure. And if it is something I can do, how difficult is it to remove the front side of the fairing? Thanks for you help.
Old Aug 13, 2008 | 03:05 PM
RonH's Avatar
RonH
It's very easy. Fairing comes off with 7 torx screws - no problem. I helped a friend install cruise in his bagger last year and it was fine. Get the service manual because you will need it for a couple steps as I recall
Old Aug 13, 2008 | 03:47 PM
mrtnz03's Avatar
mrtnz03
1st Gear
Thanks for the help. Im going to tackle it myself and hopefully everything comes out fine. Although, I will have to get a service manual. See ya.
Old Aug 13, 2008 | 04:56 PM
blueflht's Avatar
blueflht
biggest issue you will have will be lifting tank from frame to run wires and cable and hookup to the injector body
Old Aug 13, 2008 | 05:00 PM
garyhendley's Avatar
garyhendley
cant go wrong if you have the manual-ride safe
Old Aug 13, 2008 | 06:27 PM
mrtnz03's Avatar
mrtnz03
1st Gear
The description from Harley states one does not have to remove the tank? So do I have to remove it, or just simply lift it to run the wires? Thanks for all the replys.
Old Aug 13, 2008 | 06:34 PM
Sodiee's Avatar
Sodiee
I think you'll find out that cruise controll is on of the best items you'll ever put on your bike.I know it's one of my favorite.Good luck!
barhog
Aug 30, 2011 02:52 AM
inverse121
Sep 25, 2010 10:25 AM
buddabelch
Electrical/Lighting/Alarm
May 11, 2009 09:46 PM
tanglefootrgu
Feb 24, 2008 07:11 PM
lightu
Jan 22, 2007 05:54 PM
