true dual conversion ?
Old Aug 14, 2008 | 01:25 PM
rick's Avatar
rick
Default true dual conversion ?
I have the se performance slipons as well as the stage1 w/heavy breather.I want to go true dual especially for the heat issues but cant afford them at this point.My question is concerning the fulsac true dual conversion kit.Opinions please from those who have them.If you have them with se slipons it would be even better.I may try rinehart slipons later if i add the conversion kit.hope someone can help me out here.
Another reason i wont be able to do actual tru duals is the added cost of doing what ever needs to be done extra after you add tru duals.reprogram etc.
Old Aug 14, 2008 | 01:59 PM
aquaskiman's Avatar
aquaskiman
I have the fulsac true dual conversion and the 2” baffled stock mufflers, great set up George
rocknrod's Avatar
rocknrod
I am using the true dual from fulsac on the left side. Since the Samson true duals on the left dont fit properly and they dont care
Works.
Old Aug 14, 2008 | 02:15 PM
1hagop's Avatar
1hagop
I have the fulsac on my RG and love it. I have B&E super flows with 2" baffles and I like the sound, same on RH and LH sides! Noise level good at idle then bark when you get on it. I have Ness A/C, stage one D/L and IED's
Old Aug 14, 2008 | 03:34 PM
BigGstreetglide's Avatar
BigGstreetglide
where can i find Fulsac? i would like to check them out. am also wanting true duels.
Old Aug 14, 2008 | 03:41 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Changing over to any True Dual system will require you to change\up-date the ECM. Hoping you have a PCIII or V&H or other Fuel Management System you can make the changes and didn't waist your $$$ on a Dealer Download. Have heard nothing bad about the Fulsac Change over.
If you're thinking about Rhineheart Slip-ons they will be a lot quieter then there True-Duel Set-up
Old Aug 14, 2008 | 03:47 PM
downsmith's Avatar
downsmith
I have the Fullsac conversion and Hooker Tuned Flow slip-ons. More heat on the left side.
Hooker says DO NOT use the Harley ECM updates when using their pipes as they are still not rich enough. I guess if you want something done right, do it yourself.
Find FULLSAC (2 L's) at fullsac.com
Old Aug 14, 2008 | 03:48 PM
Harleypingman's Avatar
Harleypingman
+1 on the need to reprogram/alter the ECM with Fulsac or other true duals installed.
Exercise some patience, bro--get what you want when you can comfortably afford it.
Old Aug 14, 2008 | 04:06 PM
rick's Avatar
rick
I thought with the fulsac tru-dual coversion kit you dont have to do any of the reprogramng/alter to the ecm?
Old Aug 14, 2008 | 04:18 PM
itsmyforte's Avatar
itsmyforte
if you don't change the air cleaner you can probably get away with it. it is the lower rpm range that is the problem. The ecm can compensate at higher rpms, but at idle and below a certain rpm(approximately 2200?) you will need to richen it up a bit. i would atleast use a set of IED's with the true dual conversion and whatever mufflers you decide to use.
