Oil light coming on, help!!
Old Aug 18, 2008 | 02:45 PM
joechief's Avatar
joechief
Default Oil light coming on, help!!
I was riding my '06 RKC home Friday night and when I would pull up to a stop sign, the engine oil light would flicker. As I rode along, it started to flicker at about all lower speeds. I bought the bike a month ago and it had 750 original miles on it. I rode it up to 1,050 and changed all the fluids, putting Screamin Eagle Syn. and a new filter. I went to Sturgis and back and now have 2,400 miles on it. Of course I checked the oil immediately and it was right between the 2 marks and looked and smelled fine. I rode the bike Sunday and had no oil light at all. Any ideas, potential problems or just a gremlin?
Thanks,
Joechief
Old Aug 18, 2008 | 03:22 PM
troy.j's Avatar
troy.j
On my EVO there was an isue with the screen and spring under the sender being dirty. i would start by pulling the sender and clean it and see if there is a spring and screen under it to clean as well.
how hot the bike gets with also make a change. hot = thin oil...
Old Aug 18, 2008 | 03:25 PM
vindyl's Avatar
vindyl
Mike flht does that also. Change to straight 60 weight oil in the summer time should stop the problem. Most likely the oil is very hot and very thin and won't pump at low rpm's.
Old Aug 18, 2008 | 03:28 PM
dougbk's Avatar
dougbk
My oil pump started eating itself on my 06 UC. I found it while doing an oil change and noted some extra metal on the drain plug.
Old Aug 18, 2008 | 05:43 PM
FXSTDSE2's Avatar
FXSTDSE2
Check it with a quality gauge. 3-6 psi HOT idle and 30-36 @ 2500. Thats about the norm. It it is less then that with 20-50 you have a pump problem.
tgarrett1
Oil Archive (no new posts)
Mar 25, 2020 01:36 PM
sluginxlt
EVO
Sep 25, 2016 10:21 PM
jacknthebox
Jun 15, 2013 06:46 PM
pjsonnentag
Oct 12, 2012 09:13 AM
Strgzr
Exhaust System Topics
May 1, 2011 10:06 AM
