Small oil seep between!!
Old Mar 20, 2006 | 07:40 PM
Tn.Heritage's Avatar
Tn.Heritage
Default Small oil seep between!!
Ok let me try to explain where it is, on top of where the motor and trans bolts together on the left side of the motor, it seaps oil about 4" long, I'll wipe it off and after a ride it's back.
Now I have talked to the dealer about this and the tech said that there were no oil passages in between the tranny and the engine, so where the heck is it coming from, could it possibly be from a dowl pen, the way I look at it it's got to be a leak from somewhere and he's done talking like it can't be fixed and it shows up more because it's the plain colored engine, can't fix it, this is not what I want to here.
Has anybody else had this issue?
Old Mar 20, 2006 | 08:24 PM
websterdan's Avatar
websterdan
Default RE: Small oil seep between!!
Process of illimination. Wipe everything clean, soon as you get back. Starting from Rocker boxes down. Come back every5-10 min and check all the parts you wiped.
Old Mar 20, 2006 | 08:30 PM
Scout's Avatar
Scout
Are you talking about the primary chain case? If so, it holds oil, has a ring gasket, and has 7 bolts that are threaded though that are sealed with black RTV. Is it possible to post a pic of the area where it's leaking.
If it is the primary case gasket, it's not a big deal to replace it.
Old Mar 20, 2006 | 08:55 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
ORIGINAL: Scout
My primary gasket seeps oil at the top for about a 4' area like described above. It's an easy fix but I have found that WD40 cleans the silver motors very well. I just don't feel like taking off my pipe and floorboard to fix it at this time.
Old Mar 20, 2006 | 09:24 PM
HDFF03's Avatar
HDFF03
Try here http://*******.com/rcot8 and here http://*******.com/lmfax
Old Mar 20, 2006 | 09:26 PM
Scout's Avatar
Scout
It won't let me on! Can you post it here?
Old Mar 20, 2006 | 09:32 PM
HDFF03's Avatar
HDFF03
The links are posts on another forum and they are multiple pages, and I mean multiple. You may have to register to read them, takes a couple of seconds.
Old Mar 21, 2006 | 12:42 AM
Tn.Heritage
Well from what I can find out it may be several things, it could be the seal between the case not sealing or it could be a sand hole in the case, hope that ain't it.[&:]
Old Mar 21, 2006 | 05:43 PM
HDFF03's Avatar
HDFF03
I had my cases resealed and it has been fine since.
Old Mar 22, 2006 | 03:12 PM
Kahuna's Avatar
Kahuna
ORIGINAL: Tn.Heritage
You can also check the primary shaft seal! This seal is a piece of Sh%*! I had it replaced on both my Road King and Road Glide! This seal, if leaks, will drip oil from under your Derby cover.
