Spark plugs
Old Aug 21, 2008 | 04:05 PM
6speed's Avatar
6speed
Default Spark plugs
I am doing the 10,000 mile service,and will change the spark plugs.I currently run the stock 6R-12, I also run the V&H ovals,sert and the larger air filter.Question, any reason I should not run the same plug? and if not, what would be a better plug for my set-up? and proper gap? Engine is stock otherwise. Thank you.
Old Aug 21, 2008 | 04:16 PM
newrench's Avatar
newrench
gap is .038 to .043 and 6R12 is fine for your set up.
Old Aug 21, 2008 | 04:23 PM
chiefparry's Avatar
chiefparry
I've read on here that the plug does not make much difference.
Old Aug 21, 2008 | 04:33 PM
newrench's Avatar
newrench
I have to agree.
Old Aug 21, 2008 | 05:14 PM
dawg's Avatar
dawg
I run Autolite 4164's in my scoot. I always gap at .040
Old Aug 21, 2008 | 05:17 PM
newrench's Avatar
newrench
I run the golds there supposed to run "cooler" for my high compression build.
Im sure the 6R12 will do the same thing LOL****
Old Aug 21, 2008 | 05:26 PM
SteveXL's Avatar
SteveXL
I went from stock to the SE Tripple Platinums and noticed no difference. I am now running Golds and will stick with them.
Old Aug 21, 2008 | 06:31 PM
Mick's Avatar
Mick
The stock plugs are fine and work really well with most builds.
Shoot , they're not even expensive compared to other plugs.
If you do change to another plug number , you will be introducing an "unknown variable" to your present tune , which can complicate tuning even further.
An example would be that you get a plug that fires better (more completely) than stock.
The computer "sees" (through the oxygen sensors) that the fuel mix is lean.
The computer then tries to add fuel to make up the difference.
The tune is now "off a little".
Or you get a plug that runs colder.
The computer "sees" that the burn wasn't complete (rich).
The computer tries to deliver less fuel to compensate.
This would be a really simplified version of what happens , but you get the idea.
I run into this daily with auto repair , and it really makes a difference on cars and trucks.
Stock plugs are good...
Mick
Old Aug 21, 2008 | 07:31 PM
jag1886's Avatar
jag1886
Autolights are the way to go and always buy the cheapest ones they work just as good as any gimmick spark plug. Been using them for 30 years in everything I own, never had a failure.
Old Aug 21, 2008 | 07:35 PM
crash1292's Avatar
crash1292
arnt autolight bases just unplated steel?...seems to me they rust up last time I used them in my cage
