Derby Cover Gasket Question
Old Aug 29, 2008 | 12:25 PM
fotoflojoe's Avatar
fotoflojoe
Default Derby Cover Gasket Question
A few weeks back, I did the 1k service on my 08 Ultra. Prior to that, I went to the dealership to get the parts. When I asked for a derby cover gasket, the parts guy gave me the "usual" six inch round paper kind. When I pulled the derby cover, the gasket used was a rubber O-ring seated in the derby cover itself.
The next day, I go back to get the correct gasket and a different parts guy tries to give me the same thing. I say no, it's an 08, it uses a rubber O-ring, not the paper disk. He says the paper gasket is the new, improved version. When pressed, he produced a service kit that had the proper part.
Was he correct? is the paper gasket an update? I tend to doubt it, since the original gasket had the same part number as what fits my old 06 RK. Also, the 08 service manual makes no reference to changing gasket types.
Old Aug 29, 2008 | 12:34 PM
TMART's Avatar
TMART
I went in to my dealer last saturday and asked for a derby cover seal for my 07.He sold me a rubber flat type o-ring seal that came with 3 small o-rngs which he said are for the drain plugs
Old Aug 29, 2008 | 12:53 PM
Tinkermc's Avatar
Tinkermc
my 07 uses the o ring type
Old Aug 29, 2008 | 01:04 PM
dawg's Avatar
dawg
17369-06 is the derby o-ring kit with 3 11105 o-rings and is for 06 Dyna and 07 and later touring bikes. The derby o-ring works on the stock derby cover only. If use another cover then you use 25416-99C which is the disc
Old Aug 29, 2008 | 01:30 PM
beanok's Avatar
beanok
O-Ring seal with 3 small O-rings that 's what I got from my dealer.
Larry64
Aug 10, 2012 07:28 PM
ssls6
EVO
Feb 15, 2009 07:28 AM
DJM
Jan 4, 2009 08:47 PM
steelhead
May 27, 2008 01:36 PM
WdGldDave
Aug 3, 2006 02:56 AM
