changing brake fluid ????
Old Aug 29, 2008 | 02:19 PM
mtairy biker's Avatar
mtairy biker
Default changing brake fluid ????
I have a 04+05 bikes I have never changed the brake fluid someone told me it should be changed . i am not sure the H-D owners manaul does not say anything about it
the 04 takes dot 5 the 05 takes dot 4
Thanks Larry
Old Aug 29, 2008 | 02:22 PM
07RoadHawg's Avatar
07RoadHawg
Should be changed every 2 yrs, just like any other brake system. Not only does the fluid get dirty and affect braking components, but the fluid collects water (also affecting the components). Check your service schedule in the back of the manual. If I remember correctly, it makes mention of it somewhere on that table.
Old Aug 29, 2008 | 02:23 PM
mtairy biker
Thank you matrix5 for a quick responce I am heading to the NAPA store now
Old Aug 29, 2008 | 02:55 PM
Richpend's Avatar
Richpend
Is it easy to change? Mtairy Biker your sig picture is way to cool!
Old Aug 29, 2008 | 03:02 PM
jsimo7's Avatar
jsimo7
It is easy you can either buy a small hand vacuum pump or get a helper and pump up the brakes and open the bleeder a few times until clear fluid comes out (keep the master cyl full so no air gets in the brake lines) ..... be careful and cover any painted parts because dot 4 will eat paint off the anything it touches
Old Aug 29, 2008 | 03:27 PM
Richpend's Avatar
Richpend
Thanks alot!! I'll just have to becareful!
Old Aug 29, 2008 | 03:42 PM
mtairy biker
yes my brother in law is a mechanic i plan to borrow the hand pump model from him he has both one for a compressor and a hand pump one I just got a bottles of 5&4
Old Aug 29, 2008 | 03:49 PM
blueflht's Avatar
blueflht
all you need is a turkey baster or hypo from cajun seasoning. suck out the old oil and wipe resovior clean refill then crack lines and bleed. go ahead and do pads while your at it!
Old Aug 29, 2008 | 03:52 PM
mtairy biker
allready changed the pads front and rear to the lyndal z pads not to long ago
Old Aug 29, 2008 | 05:28 PM
Dennydp's Avatar
Dennydp
Check out Steves post on the speedbleeders.
rwt
Jun 22, 2017 06:58 PM
EasTexUltra12
Jul 14, 2014 09:21 AM
Sgt_Jim
Apr 5, 2011 09:35 PM
rlchristensenmd
Wheels/Tires
Sep 14, 2009 03:05 PM
NYSportster
Wheels/Tires
33
Feb 14, 2009 09:39 AM
