Brake Pad Replacement
Old Sep 2, 2008 | 10:43 AM
52edub's Avatar
52edub
Default Brake Pad Replacement
After seeing all the praises for Lyndall brake pads I had my pads replaced when I had the front tire replaced. How much drag should I expect? The front wheel when off the ground barely spins freely. I hear the pads dragging on the rotors. Is this normal or should the wheel spin freely? Because of the resistance, I pulled both rotors and cleaned them throughly as per Lyndall instructions on their website. Looking for input, thanks.
matt
Old Sep 2, 2008 | 05:03 PM
soos's Avatar
soos
You should have some drag. Your wheel will not spin freely. This is normal.
Old Sep 2, 2008 | 05:15 PM
mtairy biker's Avatar
mtairy biker
same here a little drag here too
Old Sep 2, 2008 | 07:53 PM
hogdvr's Avatar
hogdvr
I just did a Lyndall Gold Plus upgrade on my low mileage '06 ultra. Scotch-brited the HD floaters, completely cleaned and polished the calipers, flushed the fluid, bled it all out, and it still has some drag. It's normal.
buboje
May 14, 2018 06:27 AM
Striker951
Aug 30, 2010 02:10 AM
1bagman
Wheels/Tires
Nov 29, 2009 03:20 PM
HIKER
Apr 4, 2009 04:31 PM
hogdvr
Aug 31, 2008 06:17 PM
