Oil blow by!
Old Sep 4, 2008 | 03:03 PM
Mississippi Bagger's Avatar
Mississippi Bagger
Ya got too much oil in the engine....or you got a serious problem.
If you keep the oil level down around the halfway mark (or a little lower) when cold, you can run em hard with no oil spewing outta the a/c.
Old Sep 4, 2008 | 03:07 PM
dawg's Avatar
dawg
Originally Posted by scootertramp
I'd much rather do it externally. There's gotta be a way.
Tap the two holes where the oil comes out in the intake area and put a set screw in each one with red loctite. This will plug the holes. Then drill and tap the breather bolt sleeves where the bolts hold the plate to the heads and insert NPT to ****** fittings and run oil line from each one down to a tee fitting underneath the air cleaner. Then run a line from the tee down to the ground. This is what I did.
Old Sep 4, 2008 | 03:31 PM
JCTulsa's Avatar
JCTulsa
This thread is worthless without pics
cvaria
Mar 20, 2017 01:11 PM
mikeo33y
Jun 8, 2014 08:47 PM
phattey
Nov 28, 2009 04:38 PM
scootertramp
Exhaust System Topics
Sep 5, 2008 10:26 AM
Jessie
Oil Archive (no new posts)
Aug 27, 2008 12:24 PM
