How much oil is too much?
Old Sep 4, 2008 | 05:24 PM
honestbob's Avatar
honestbob
how much oil you need depends on how it's drained. How long did it it sit before you drained it, engine hot or cold, on lift or leaning,change the filter before or after pan is drained? all this has to do with how much oil is left in system. I always put 3 1/2 in, ride it awhile and add a little when needed.
Old Sep 4, 2008 | 05:28 PM
TheBlackBastard's Avatar
TheBlackBastard
If your air filter is puking oil, you put in too much!
Old Sep 4, 2008 | 05:52 PM
harley-jones's Avatar
harley-jones
Originally Posted by captjon37
How do you make a simple oil change turn into a complicated mathematical equation? Start at the top and read again. I just do what the book says to do no mater how HARD it is. I need the extra exercise.
If you can't answer the question.......Move on to another post, I don' need a lecture
Old Sep 4, 2008 | 05:53 PM
n8dc's Avatar
n8dc
I put 4 quarts im my glide but i also changed the trans fluid and the primary and i did it all hot and i let the engine drain while i did the rest and i was amazed i needed the full 4 qts . Musta drained a lot out while it was good and hot.
Dave
Old Sep 4, 2008 | 07:06 PM
mosiermel's Avatar
mosiermel
4th Gear
I have a stock, 2004 Elec Glide Classic. The repair manual says the oil capacity is 4 quarts. The recommended procedure is to put in 3.5 and than add oil until it shows full on the dip stick.
Regards,
Mel
Old Sep 4, 2008 | 07:57 PM
themensh's Avatar
themensh
3.5 to 4 qts. (Check the dip stick.)
Geesh.....can we move on to "tire pressure.....nitrogen or regular air pump?"
Old Sep 4, 2008 | 08:09 PM
04harleyboy's Avatar
04harleyboy
I my 07 service manual it says the engine capacity is 4qts, when doing an oil change to replace the oil with 3.5 qts, this is due to the amount of oil that will not drain out, and can only be removed with a cleaning (as in engine rebuild). I put in 3.5 qts, my buddy who does not believe me puts in 4qts, and has oil dripping out of his A/C constantly. Just put in 3.5 take it for a drive, when you get home check it, then you will know.
Old Sep 4, 2008 | 08:33 PM
MNPGRider's Avatar
MNPGRider
the Harley is the only engine I have ever owned which requires an oil level check with a hot engine. and then they put the frickin' oil cap right next to the exhuast pipe.
Old Sep 4, 2008 | 08:47 PM
Lucky 13's Avatar
Lucky 13
4.0 quarts from dry, if you could possibably drain it all out. Usally there is about a half quart left in the crankcase, more or less. that is why 3.5 works, then top it off hot, 200 degrees or more. Its better to be a little under the high mark than over at all.
Old Sep 4, 2008 | 09:06 PM
captjon37's Avatar
captjon37
I did answer the question and think that you must be incredibly lazy if you are looking for an easier way to get the oil level right other than checking it.
