How much oil is too much?
Old Sep 4, 2008 | 09:17 PM
oldfartjc's Avatar
oldfartjc
I drained it hot and let it drain for awhile. It took 4 quarts to bring it to the half way mark on the dipstick when cold. I also drained almost 4 quarts out of it so it must be right.
Neckball's Avatar
Neckball
I was hoping while I had it on the lift I could just put in X-amount of oil
Unless you have a table lift, it's easier to do the oil change on the ground with the motorcycle on the side stand. If it's on a lift I'm not sure how you get a drain pan under it.
Just put 3.5 or so in it and check it. Add as necessary. It ain't rocket science.
Old Sep 4, 2008 | 09:25 PM
mountian man's Avatar
mountian man
Book calls for four quarts with filter,Not hard to figure it out.Put in four quarts with filter.
Old Sep 4, 2008 | 09:53 PM
harley-jones's Avatar
harley-jones
Originally Posted by captjon37
I did answer the question and think that you must be incredibly lazy if you are looking for an easier way to get the oil level right other than checking it.
Lazy, No, just trying to work smart and get things right the first time. If it bothers you that I asked what I felt was a legit question tough s###t.
As you can see by the answers and if you read them some are putting in 3 1/2 some are putting in 4Qts. So you do it your way by the book and I will ask for answers on this forum. Which is what forums are for.
Does the owner manual tell you at what temp to check your oil..No!
Do some folks have oil come out of the A/C at 4Qts.....Yes
My question is what others are doing and if anyone has figured out a cold fill level that is correct.
Peace!!
Old Sep 4, 2008 | 10:02 PM
biz44's Avatar
biz44
Not rocket science here guys. After you drain the old oil and remove the old filter, then just let it drip a while.
Then I add a bit of fresh oil to the oil filter....put the new filter on. Then dump in 3.5qt. Take her around the block and then check the dip stick. On my SG I normally have to dump in the rest of the fourth quart to get it to the top of the cross hatch area of the dip stick
cmcsns's Avatar
cmcsns
From: Beverly Hills, Fl. Swimmin pools. Movie stars
STOP IT I can't take this pressure!!
Old Sep 4, 2008 | 10:13 PM
captjon37's Avatar
captjon37
No, not bothered, just bewildered by such questions. Is checking the oil in a bike so different than any other motor with oil? Do you really need an owners manual to tell you that the oil must be at working temp to get an accurate reading? You want a cold fill level just do the oil change right the first time then check it when it cools. Problem solved. Peace be with you.
Old Sep 4, 2008 | 10:33 PM
Fat Boy 07's Avatar
Fat Boy 07
just check it hot...don't overfill
Old Sep 4, 2008 | 10:34 PM
skratch's Avatar
skratch
i change my oil using a condor chock to hold the bike upright. otherwise, i cant get a drain pan under it. get it hot, pull into the chock, put the pan under it, put on my mechs gloves (helps when you get hot oil on your hands lol) and let er drain for a while. when filling, i do like the book, and put in 3.5 qts. ride for a bit, then check it, and the level is usually just above the halfway mark in the hatched area so i leave it alone. no oil spewing out of ac for me!
Old Sep 4, 2008 | 10:35 PM
harley-jones
Now you have answered the question! Took a while to get it out of you.
Forums work so much better if you answer questions and don't just write words to make someone questions seem dumb.
My parents taught me "There is no dumb question" and I believe that.
And thanks to the people that did answer this question properly
