White spark plug tip.
Old Sep 6, 2008 | 09:23 PM
biz44's Avatar
biz44
As long as its not pinging under load your fine. I am running one heat range cooler on the plugs in my 03' SE Deuce because they were looking a bit too light in color. Now they look a perfect light tan, and the bike runs fine. It dont ping at all even on regular fuel <90 octane.
Old Sep 7, 2008 | 03:36 AM
GT_RoadGlide's Avatar
GT_RoadGlide
I think there's a lot of good advice in this post.
or you go overboard... for around $600-800 get a couple wide band sensors and A/F ratio meters and monitor the A/F ratio as you ride it.
Old Sep 7, 2008 | 10:45 AM
hamnhog's Avatar
hamnhog
A dyno run and a look at the AFR curve afterward are pretty good tools to analyze this type of thing. A local crotch rocket shop here will dyno a bike for $50. That would at least provide some peace of mind.
Old Sep 7, 2008 | 11:11 AM
04harleyboy's Avatar
04harleyboy
To answer your question as best I can. The HD dealer download is EPA compliant, which means it will be on the lean side, but no leaner then when HD shipped your bike to the dealer. It should be fine.
Old Sep 7, 2008 | 11:21 AM
spizzyman's Avatar
spizzyman
Thanks for noticing the part about the download. It helps.
spiz
Chuck U. Farley
2014-2024 Touring Models
15
Mar 15, 2015 02:23 PM
jacknthebox
Apr 2, 2012 08:43 PM
Stomper-63
Aug 30, 2010 12:11 PM
kenward
Jul 31, 2009 08:42 AM
Jessie
May 10, 2008 12:02 PM
