Harmon Kardon Problem HELP
Old Sep 8, 2008 | 08:47 AM
1Reaper's Avatar
1Reaper
Default Harmon Kardon Problem HELP
This weekend my 08 SG Harmon Kardon seems like it went into "protect" mode or something. It only goes to about 2/3 volume, I try and turn it up loader and it stays at that lower volume????
Is there a way to factory reset?
Did it get hot or somthing?
Any help would be great.
Thanks
Old Sep 8, 2008 | 08:49 AM
HDUltraRider's Avatar
HDUltraRider
Where you playing the radio or CD's if you were using CD's or an MP3 player and changed it could be the recording.
Old Sep 8, 2008 | 08:51 AM
1Reaper's Avatar
1Reaper
It did it with different CD's and the radio...
Old Sep 8, 2008 | 09:01 AM
blueflht's Avatar
blueflht
take it back to the dealer. its a common problem with the h/k radios. if its under warrenty get another radio. unfortunately the refurbs arent much better than the new ones
Old Sep 8, 2008 | 09:03 AM
1Reaper's Avatar
1Reaper
I rebuilt this bike from the ground up after a wreck, so no warrenty...
Old Sep 8, 2008 | 09:21 AM
lasvegasrick's Avatar
lasvegasrick
if it does it when you are rolling check your alc control maybe set too high
Old Sep 8, 2008 | 09:23 AM
blueflht's Avatar
blueflht
reaper if you need a refurb try to get your dealer to send yours back. 275$ is the cost of a refurb radio. might try pulling battery cable to reset
Old Sep 8, 2008 | 09:25 AM
1Reaper's Avatar
1Reaper
I have it set at 3 is that to high? There is only 1 2 3 4 bars correct?
I am def in one ear and play my stereo load with JM speakers.
Old Sep 8, 2008 | 09:26 AM
1Reaper's Avatar
1Reaper
I have the main fuse pulled as we speak trying to reset it. If I spend any money on this it will be getting a new head unit and amp, not another crappy HK...
Old Sep 8, 2008 | 09:32 AM
blueflht's Avatar
blueflht
if you want check with firecap501 . he has arc audio setups that are awesome. alpine has a head unit that is really nice
http://www.alpine-usa.com/US-en/prod...model=iDA-X300
Harley Hound57
Aug 18, 2012 04:54 PM
eohdtech
Mar 11, 2010 09:09 AM
hfdarson1
May 24, 2009 06:29 PM
PHREDD71
Apr 4, 2009 06:53 AM
