Cam School
Old Sep 10, 2008 | 07:25 AM
bazam9s's Avatar
bazam9s
Default Cam School
Hey guys, I need some schoolin'. Thanks to this forum and you guys, I'm going forward to install a gear drive cam in my 05 EGS. I think I know what cam I want but I'm comparing brands and specs. In a previous thread Harleypingman (Carl) was nice enough to provide this awesome link to the Big Boyz Cam Comparator. Here it is:
http://www.bigboyzcycles.com/tccams.htm
Here's my questions,
What role does "Duration" play in HP/TQ performance..or does it?
And what exactly is Overlap?...Is more or less better?
Old Sep 10, 2008 | 08:23 AM
miacycles's Avatar
miacycles
All of the above questions about cams and more are answered at nightrider.com.
Duration is the amount of time computed in crankshaft degrees that the cam holds the valve off of the seat. The greater the duration the longer the valve is off of the seat. Up to a point, this allows the engine to breath better. In general engine displacement and desired RPM's dictate what duration will work best. Increasing duration of a cam will move the power higher up the RPM.
Overlap is the time measured in crankshaft degrees that the intake and exhaust vales are open simultaneously. This happens near TDC when the exhaust is closing and the intake is starting to open. The amount and where the overlap has a major effect on power. As duration increases overlap increases all other things being equal. As overlap increases you should increase mechanical C/R . In general for a given engine the shorter the overlap the lower the RPM will be for maximum torque. Overlap changes may require exhaust changes to take advantage of the change in the inertia of the exhaust and intake pulses.
Hope this helps.
P.S. If you have a bagger or heavier bike try any of the Woods "6" series of cams, or give Bob Woods a call. If you use one of his cams you won't be sorry.
Old Sep 10, 2008 | 08:28 AM
blueflht's Avatar
blueflht
thanx for the complete and precise lesson miacycles! SCHOOL IS DISMISSED!!
Old Sep 10, 2008 | 08:36 AM
bazam9s's Avatar
bazam9s
Hope this helps.
Hey Miacycles, thank you for the explanation, that really answered my questions. I have also heard a lot about Woods cams on this forum and it was one of the cams I have been comparing along with Andrews. All good reviews on them. I will give Bob a call.
Again, thanks for the schoolin" teach!!
Old Sep 10, 2008 | 11:48 AM
Harleypingman's Avatar
Harleypingman
Glad to help. I used Head-Quarters HQ-0034 cams and highly recommend them--many happy users on HDF.
The 34's have an intake close of 36* which provides earlier torque than a later closing 40* intake.
Good luck with your choice.
Old Sep 10, 2008 | 12:01 PM
miacycles's Avatar
miacycles
Wow I didn't even cover LSA, so I will add it now. Cams with short duration, high lift and a narrow LSA give you more low and mid-range power. For more top end power longer duration and more LSA are better. As I believe it is PhilM has in his signature "All parts need to enhance/balance each other".
Old Sep 10, 2008 | 01:01 PM
bazam9s's Avatar
bazam9s
Carl, what is LSA?
Old Sep 10, 2008 | 02:41 PM
miacycles's Avatar
miacycles
LSA is Lobe Seperation Angle. It is the angle of seperation in camshaft degrees between the centerlines of the intake and exhaust lobes.LSA determines the valve timing and overlap period for a given duration, therefore it has a major effect on the power characteristics of a given cam. Mild V-Twin cams usually range from 100-104 degrees. While the hotter cams are between 103-110 degrees.
Hope this helps.
Old Sep 10, 2008 | 03:36 PM
bazam9s's Avatar
bazam9s
Hope this helps.
Thanks John, your explanation is very clear and helpful. I learned alot today. Now if you can please stop by my garage in MA and help me install this cam that would be great! LOL
(oh yeah sorry I called you Carl in the last post..got mixed up)
Thx
Old Sep 10, 2008 | 06:31 PM
miacycles's Avatar
miacycles
You can call me Ray or you can call me Jay, but you don't have to call me Ray-Jay!!!Heck I am not that far from you stop over here, and fix my Verizon cell phone!!!<BFG>
