Is it worth getting ABS?
Everyone here has been concentrating on the "emergency" aspect of ABS and what it can do for you. Yours is not the first story of it's kind I've heard about and speaks volumes to the point that ABS can be of benefit regardless of how careful you're trying to be!
Glad it worked for you!
I have been praying for abs on Harleys forever I bought one immediately last yr
Dont think about it, your life is worth more than the cost
scoote2008
My oldest (who rides the '08) didn't buy the bike until HD offered the ABS last year. Ditto for me, but on an '09. I feel that strongly about it. Riding a bike is certainly more dangerous than a car but it is what I choose to do; However, I also want to give myself the best chance to survive vs risk.
As always, your mileage may vary. <grin> As we said in the 70's, "Keep the shiny side up, and the dirty side down".
Cheers and all the best, geeded
I did not hit it!
But I wonder...Would an ABS bike have been any easyer to handle or not? I don't know.
Hopefully I won't have to find out.
I did not hit it!
As for downsides? The only situation I've heard of where a standard braking system will consistantly do better than ABS applies to cars and is on a heavily graveled road. Without ABS, the wheels simply lock and the gravel piles up in front of the tires and slows the car. With ABS, the system keeps the wheels turning which allows the gravel to roll under the tires with predicable results. I seriously doubt that this situation applies to motorcycles because we're not going to be going that fast on a heavily graveled surface. We'd be too concerned with simply staying upright to worry about ABS or the lack thereof.
I can't honestly think of a situation where ABS would be a negative on a motorcycle from an operational point of view. I'm not saying there isn't one, just that nothing comes to mind right now. One poster noted the cost of repairs if you ever had a problem with it. That might be one negative but considering that ABS technology has been around for a very long time now and has proven to be quite reliable, I don't consider it to be a significant one, certainly not enough to offset the positive aspects that have already been discussed in this conversation.
JMHO!
Ride Safe,
Steve R.
I have also been driving cars as long with ABS brakes. They work every now and again in situations that are not life threatening or car bending.
The point I will make is that we live in safety averse times and ABS panders to that. I have yet to experience ABS in a situation that is helpful or beneficial to me and I reckon most of us will never benefit from it. As it gets cheaper to fit, more bikes will have it as standard and we will increasingly regard it as essential.
But most riders with it on their bike will probably find it never works, just as I have found. In other words not many of us ride in such a way that we are likely to make it trigger into action. It will be interesting to revisit this topic in a couple of years time to see how many Harley riders have actually benefitted from having it. I have not and can see no use for it. But then I see no use for a radio/cd/tape on a bike either, so would prefer to have neither, save some weight and put the bucks to something I would find more useful.
O.K. stop using foriegn language on here. Some of us understand what LOGIC means, but it is obvious many don't. Please stick to words EVERYBODY can understand!!!!
ABS brakes use a computer chip to analyze your braking conditions many times per second. The human brain is not capable of monitoring this nearly as good as a chip can. ABS brakes will let you make a safe, controlled high speed panic stop without letting the front wheel or rear wheel lock up due to uncontrolled pressure from the operator using either the hand grip or rear brake pedal. They work. I have experienced it first hand. I have seen other riders who were in a panic stop condition and it worked for them too. A crash is bad enough when in a car, if you are in a motorcycle that is the last thing you want to happen. Coming in contact with sheet metal and iron such as a car while riding a motorcycle is probably going to result in a 911 call, at best.
So why not spend an extra $800.00 dollars for the best braking technology out there. For me, it was an easy call.
