problems with a Evo
Old Oct 21, 2008 | 10:47 PM
iclick's Avatar
iclick
Originally Posted by lionsm13
You might try the "Haden oil fix kit" for that blow by thing.
The Hayden "Oil Fix" corrects base-gasket leaks, so I doubt if it'll repair the OP's problems with blow-by.
Old Oct 21, 2008 | 10:59 PM
iclick's Avatar
iclick
Originally Posted by 98 roadglide
...its all fricking new. it still leaks,not as much as before.
The Evo is a very dependable motor when set up properly, but the oil barfing is something you might need to get used to. My '96 RK barfed, although not much as you're describing, and so does my '07 SG. In the latter case I installed the Fuel Moto modded SE AC that channels the breather oil into the velocity stack, and thus gets sucked into the intake never to barf through the filter element again. I would call Jamie at Fuel Moto and ask if a version is available for your bike, although he doesn't list it on his website.
The Evo uses no oil pressure in a conventional sense except for the lifters, and your pressure sounds close, although it depends on the accuracy of your gauge. Hot pressure of 20# is about right, and you could see zero on a gauge at idle when hot, although it isn't really zero if the lifters stay quiet. Your OP light should not be coming on, however, but if it flickers at idle when very hot I wouldn't worry too much as long as it picks up above idle and you hear no lifter clatter. If the lifters are not clattering you have enough pressure.
zyonsdream
Feb 17, 2014 02:25 PM
BKSinAZ
Dec 13, 2012 05:58 PM
bborner
Aug 12, 2010 11:33 AM
tims
EVO
Aug 17, 2007 02:12 PM
Russell
Oil Archive (no new posts)
14
Nov 11, 2005 02:29 PM
