Pass. Seat Strap
Old Sep 21, 2008 | 04:15 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Pass. Seat Strap
I'm assuming I can remove the chrome passenger seat strap brackets, since the strap is useless.
You would think HD would have screwed both sides down with phillips head screws. NO, they have to rivet one side to cause us extra work.....
Guess I could drill out the rivet if need be but my luck, I would nick the paint job somehow.
Old Sep 21, 2008 | 04:25 PM
04harleyboy's Avatar
04harleyboy
My 07 had bolts. It was the first thing I did, remove the strap!
Old Sep 21, 2008 | 04:29 PM
bigskyhd's Avatar
bigskyhd
My last five or so HD's all had them bolted on. What year did they start riveting one side? Guess that tells you how up to speed I am. Also one of the first things to go. Although the whole seat went with it out the door on day 1.
Old Sep 21, 2008 | 04:32 PM
HDV-GLIDE's Avatar
HDV-GLIDE
The brackets are bolted on. The strap is riveted to the bracket on one side.
Old Sep 21, 2008 | 04:40 PM
dawg's Avatar
dawg
Both brackets can come off unless they changed on the 09's, just gotta take off saddlebag bracket.
Old Sep 21, 2008 | 04:42 PM
HDV-GLIDE's Avatar
HDV-GLIDE
That's what I thought, thanks....
Old Sep 21, 2008 | 07:02 PM
mile high king's Avatar
mile high king
Mine has bolts, but I wish they had some sort of quick-detach clip because it's a pain as the bolt also is the front saddle-bag bracket and when you need to get the seat off, you end up losening the saddlebag bracket. It either should be it's own bolt or a quick detach.
Taking the strap completely off leaves the slots in the stock seat which doesn't look right. What I did was hook the ends of the seat strap over the bolts under the seat coming out of the fender...the strap is on, not bolted, but hangs onto the fender bolts. I wouldn't want a passenger (which is always the wife) to use it to hold onto, but it looks fine solo.
Old Sep 21, 2008 | 07:17 PM
nedster's Avatar
nedster
Useless? Well that depends, in certain states it is a requirement to have the strap to pass a state inspection unless you have a passenger backrest.
Old Sep 21, 2008 | 07:20 PM
ayebyte's Avatar
ayebyte
Mine has two bolts. It is illegal in the Commonwelth of Pennsylvania to remove the strap. I would never ever think about doing anything illegal?
Old Sep 21, 2008 | 07:32 PM
nedster's Avatar
nedster
Is it really illegal in that wonderful conservative state?
