led problem
Old Sep 22, 2008 | 07:03 AM
it took to long's Avatar
it took to long
1st Gear
Default led problem
Ok so my dad put led's on his 08 ultra classic last night he said they worked great well this morning on his way out of the neighborhood his bike went into limp home mode. now my question is, what could it be he only hooked the wires to the negative and positive posts on the battery the rest is a stand alone system?
also how do i check the codes on it?
Old Sep 22, 2008 | 08:25 AM
Casper's Avatar
Casper
Other than a Battery Tender, I avoid hooking anything up directly to the battery posts. Check into getting a fuse block terminal, several out then. I get mine from Waytec..but there are several. Get one that has a positive and negative post, hook these to the battery and run any extra electrical goodies to the terminal with proper fuse. I have my Gerbings, Zumo, LED's etc run to this type terminal, protected by fuses. There is one out there with a relay installed on the fuse block, nice.
Old Sep 22, 2008 | 08:29 AM
it took to long
1st Gear
so you think thats the problem? what kinda code would that throw
Old Sep 22, 2008 | 08:33 AM
Casper's Avatar
Casper
No idea on the code....unhook them and see if the problem goes away....
Old Sep 22, 2008 | 08:59 AM
it took to long
1st Gear
plan to but wontget a chance to get a look at it till tonight so trying to get any info i can right now
were trying not to tell mom she gets over stressed about stuff like this
Old Sep 23, 2008 | 10:28 AM
it took to long
1st Gear
before i say this im gonna go ahaed and say thanks casper the terminals arent loose but we re wired it andit worked.
now for anyone else who stumple's upon this why is it that i can get more response's from a v-rod forum than i can from the forum dedicated to mostly airhead bikes?
Old Sep 23, 2008 | 02:32 PM
Wecroft's Avatar
Wecroft
Welcome to the forum,,, WTF is an "Airhead" bike. Just askin.
You may have gotten more responses from a given forum because many people use the "New Posts" button when they log on and they may have come upon your post in the V-Rod forum first. It usually takes more than five post to figure these things out.
sonar_chris
Nov 22, 2015 04:07 PM
dinolo24
Nov 14, 2014 09:53 AM
dinolo24
Electrical/Lighting/Alarm
Nov 8, 2011 09:34 AM
Drac 1
Mar 12, 2010 10:16 AM
ultravista
11
May 22, 2007 01:36 PM
