Battery Problems
Old Oct 30, 2009 | 09:07 AM
Drac 1's Avatar
Drac 1
Default Battery Problems
Well anyway the Ultra sat a little too long and required a charge, no biggie I just hooked up the charger unit..So after about an hour or better I went out to start it..I swear I saw a red glow between the terminal and the end of hot wire..This ever happed to any of you??? Its a first for me...
Old Oct 31, 2009 | 08:29 AM
maineultraclassic's Avatar
maineultraclassic
Did you check to make sure the connections are tight?
If there is any play, it could cause an arc between the battery and the wire since it's not tight.
Steve
Old Oct 31, 2009 | 09:28 AM
robbie52's Avatar
robbie52
Agree with Steve, you have a loose connection.
Old Mar 12, 2010 | 10:16 AM
Drac 1's Avatar
Drac 1
Thanks guys...That was the problem...
Sliver1
Jun 29, 2020 06:34 PM
Joeynotz
Electrical/Lighting/Alarm
Nov 27, 2017 02:02 AM
skstrong
May 10, 2014 02:01 PM
mja52403
Jun 29, 2013 11:12 PM
Hs Fatbob
Apr 3, 2013 08:39 PM
