Battery Charger / Ground / Electrical Issues
He had this (See image: what I assume is a battery charger with a fuse compartment) hooked up to his battery. The Red cord was wired into a large white clip located under the seat of the bike.
The red cord just sort of came loose and pulled easily out of the white clip. I can only assume that he installed this cord himself to suit some sort of additional electrical need.
We replaced the Battery and connected a new charging adaptor cable. The battery is fully charged per the indicator light on my charger but the bike will not turn on. The bike did start and run fine before this cord came out.
No lights, no click sound, no anything. Its a paper-weight, with no power at all . I don't understand why removing this red cord has prevented the motorcycle from receiving power from the battery.
I have the two main positive & negative battery cords attached properly, and the battery is fully charged.
Is it possible that this red cord was a ground and now the bike will not start due to some sort of safety measure? Please help.
I cannot get it to a shop without the bike starting. What do I need to do to get this thing going again? It was his pride and joy.
Thanks,
Shannon
Thanks,
Shannon
It was probably used to provide power to another device, as it's wired directly battery Positive terminal.
I'd try reconnecting the red wire. Maybe it's powering security device or alarm that is preventing the bike from starting...or maybe it's wired to the ignition switch. It's impossible to guess without access to the bike.
It melted the post off our battery, hence why we replaced the battery.
If I am going to re-attach it. I have to re-attach the entire thing.
There are 3 or 4 empty slots in the white wiring clip under the seat. I am fairly certain that this is where the red cord came loose from. I can try to reattach it, but does it matter which slot it goes in? I don't want to melt another $200+ battery or worse electricute myself.
Thanks for your thoughts!
Shannon
Shannon
You only need to reattach the red lead. If you have no use for the adaptor cord, just cut it off.
Without seeing the wiring clip, I can't say where to attach it, but it might be wise to follow the wiring out of the exit side to see what it is powering.
Loose connections create a voltage drop. In a high current circuit that results in significant heating that can cause melted posts.
