location of bank angle sensor? 03 RoadGlide
Old Sep 23, 2008 | 04:07 PM
RoadNames's Avatar
RoadNames
5th Gear
Default location of bank angle sensor? 03 RoadGlide
trying to replace BAS on my 03 RoadGlide in hopes of curing a recurring electrical issue - bike quits for no apparent reason.
bought new BAS for $58.00 and figured it'd be an easy swap out under a side panel or under the seat. guess what? i can't find it...
also apreciate any ideas on what would cause this problem. bike was almost totalled in a wreck in 2005 and instead of replacing it, i opted to have it rebuilt. bad plan, it's never been the same since then. read and heed, i'd never do it again. just get a new one.
bike runs fine until suddenly it just stops altogether, no lights, nothing. feels like i just flipped the kill switch, except there are NO lights on the dashboard. i usually can coast over to road side, wait a few seconds or in some cases a few minutes and it'll start right up. only seems to occur at low speeds in 1st, 2nd or 3rd gear. might happen 2 or 3 times in one afternoon or might not happen for thousands of miles. either way, you can see that it is difficult to depend on as a daily driver and even dangerous if it happened on the freeway.
what else can i tell you? punched out to 95", SE aircleaner, thunderheader exhaust. bike was a real reliable unit until "my local HD dealer" helped me out. they, of course, can't duplicate the issue, and two other shops can't either.
Old Sep 24, 2008 | 04:43 AM
joker1450's Avatar
joker1450
the same problem appens to me and the code errors gave me the error in the BAS.
error in the error, it wasn't the BAS but the ignition module, check the ignition module if it smell of fried chicken..
Old Sep 24, 2008 | 09:07 AM
RoadNames's Avatar
RoadNames
5th Gear
thanks joker, not sure where that is either, can you help?
Old Sep 24, 2008 | 10:07 AM
Scruffie's Avatar
Scruffie
Not positive on your model but check under the right side cover for the module. Thats where mine is.
Scruffie
Old Sep 24, 2008 | 09:21 PM
Getyurmotorunnin's Avatar
Getyurmotorunnin
I would spend 6 dollars and replace the 50 amp CB. That was my problem. Bike was shutting down and that fixed it. The CB is right in front of the Bat and the BAS should be right behind the Bat.
Old Sep 26, 2008 | 02:06 AM
joker1450's Avatar
joker1450
it is in the alarm unit, under the seat!
let me know about the ignition module..
bstein1994
Sep 26, 2024 08:43 PM
C&J4ever
Aug 2, 2016 05:53 AM
Ceecee Paul
Aug 30, 2013 01:16 PM
RoadNames
Oct 5, 2008 09:25 PM
nnfs
Jul 5, 2006 03:15 PM
