Garmin question
Old Oct 15, 2008 | 03:51 PM
ButtMan1000's Avatar
ButtMan1000
Exclamation
Originally Posted by philgrocks
How about locating it on google map and then using the latitude and longitude and enter that into your gps and save as a favorite.
Last time I tried that with my Zumo 550 it thought I was a Dirt biker and most of the route was cross country!!!!!
Old Oct 15, 2008 | 06:17 PM
Wecroft's Avatar
Wecroft
Originally Posted by ww1flyingace
See if you guys can find the following:
12379 South, 365 West, Draper Utah
1939 West 4620 South, Salt Lake City, Utah
2105 West, 2300 South, Salt Lake City, Utah
Something tells me your addresses are screwed up.
I took the second one and tried to find it manually on Mapscourse. The 1900 block should be around the Salt Lake City Community College but there isn't a street with 4620 name/number.
I used an address that is in the same vicinity (2051 W 4700 S) and was able to find it using both the Mapscource search function and with the Zumo using the method in my previous post. (use numbers w/o the S, W, N, E) and search the entire state because sometimes the address is in a different mailing address than you might think. The college comes up as Taylorsville rather than Salt Lake City.
If your addresses are correct than I don't know WTF the answer is. It would then be time to ask the geeks at www.zumofurums.com.
Old Oct 15, 2008 | 06:49 PM
flyingace's Avatar
flyingace
I took the first one and tried to find it manually on Mapscourse. The 1900 block should be around the Salt Lake City Community College but there isn't a street with 4620 name/number.
The first address IS right next to the community college. The street does in fact have a name: bowling ave, using the name, it does pull up ok. All my life I never realized the street had a name. (I grew up at that address... mom still lives there)
The second one, also has a street name: printers row. Worked their 20 years, and the address has NEVER been listed as "printers row", always by the west/south street numbers.
So thats TWO problems solved.
The THIRD address, is in an industrial area, and does NOT have a street name. This is the one that had me asking the question in the first place. ON this one, I wonder if the area is JUST new enough, that it missed the last garmin map update?
Old Oct 15, 2008 | 08:06 PM
tatt2zzz's Avatar
tatt2zzz
Email Garmin with your problem and they should be able to help. Good luck.
gunguy
2014-2024 Touring Models
Feb 4, 2017 11:28 AM
benson1603
Aug 3, 2014 12:06 PM
leatherslinger
Road Trips
Oct 11, 2013 10:30 PM
flyingdutchman
Aug 30, 2013 04:36 PM
Booey424
May 14, 2007 07:40 PM
