Here you go...........
Originally Posted by skratch since no one answered you yet, i'll give you what i got. you will need:
2 ea heim joints 5/16-24 right hand (http://cgi.ebay.com/ebaymotors/ws/eB...m=280249330109)
2 ea 5/16-24 x 1 in hex cap screws (i used grade 5 stainless, not that much stress where you'll need grade 8, but you can if you want, but it costs more)
2 ea 5/16-24 jam nuts
1 ea 5/16-24 nylon lock nut
the bolt will thread into the lever on the transmission. but on the foot shift lever, the nylon lock nut holds the works together. all told, i spent less than 15.00 to do this. (i reused the stock linkage rod, but you can get a new spiffy one if you want. if you go that route, see if you can get one that is about 1/2 in shorter, that will give you more adjustment room)
2 ea
