Bad Radio
Old Oct 14, 2008 | 06:46 PM
gary0025's Avatar
gary0025
Stage I
Default Bad Radio
Hello guys,
I have a 2006 Road Glide and the radio display has gone blank. Radio works, back light works, just no LED characters. Also, the temperature gauge is wildly inaccurate and spends a lot of time showing 120 degrees.
Is there anything to service here, or should I just buy a new radio and temp gauge?
Old Oct 14, 2008 | 07:07 PM
PEZ's Avatar
PEZ
Hi there
This was a common issue with 06 radios--happenned to mine as well--on the day I traded it in for my 08!. The radios faceplate comes off the body of the radio as one unit. There is a main male connector on the back of the faceplate that plugs into a female socket on the body of the radio. The issue is that on 06 radios, water or condensation would "collect" at this connection point and cause the failure you have. I guess they realized the issue cause in 07, they started putting a hot glue or silicone type material around the male connector on the faceplate side so no more moisture would cause this failure. If you have a good relationship with your dealer, I say its worth a shot to see if they can "work some magic" for you
I would look for some responses from others on the temp guage--the HD temp guages are not well known for accuracy........Your sender maybe pooched???
PEZ
Old Oct 14, 2008 | 07:08 PM
Intrepid175's Avatar
Intrepid175
I can't say for the radio. My understanding on the temp gauge is that the sensor is located inside the fairing so it'a rarely very accurate in the first place, pretty much useless most of the time.
Old Oct 14, 2008 | 10:18 PM
hogdvr's Avatar
hogdvr
Had my '06 Ultra radio replaced 2 times under warranty.
Old Oct 14, 2008 | 10:23 PM
ezryder62881's Avatar
ezryder62881
May not be whats wrong but just a mention. My friend had his radio readout do that and come to find out that he had accidentally turned his dimmer all the way down.
bizzi
Electrical/Lighting/Alarm
Oct 22, 2016 03:58 PM
Kerm
Mar 2, 2016 11:30 AM
06skullglide
Aug 6, 2010 07:06 AM
onesolar
May 20, 2008 05:10 PM
Lpye
May 25, 2006 12:34 PM
