Electra Glide Handlebars
Old Oct 15, 2008 | 05:37 PM
SBW Cycles's Avatar
SBW Cycles
Default Electra Glide Handlebars
I have a EG Standard with stocks bars. Are these bars the same on a Street Glide but the Street Glide has the bar rotated foward?
Old Oct 15, 2008 | 08:19 PM
Mick's Avatar
Mick
Hey SBW , I'm pretty sure all the "Electra Glide" FLHT and FLHX models are the same bars.
The Road Glide and Road King models are different though.
I have noticed that some are set (rotated) slightly different , for no apparent reason.
My 06 FLHT were kinda high , the 09 are set kinda low.
The bars did change in 08 and 09 for the throttle by wire controls , but are backward compatible with previous years because of the right side notches for the TBW.
The notches just aren't used for the earlier model bikes.
Mick
Old Oct 15, 2008 | 11:50 PM
emwolb's Avatar
emwolb
from what i understand the eg standard bars are a bit higher, cause with the streetglide you have the fairing mounted mirrors, so they're lower than the standard eg bars. i plan on replacing my streetglide bars with taller pullback type bars and put regular harley mirrors on the bars, as the streetglide mirrors are okay, but not nearly as safe as ones which are handlebar mounted. just my opinion, but take a tape measure to the showroom, and you might see a difference. even span with your fingers/hand the two bikes. should be able to tell by the rise alone.
Old Oct 16, 2008 | 12:25 AM
redbaron72's Avatar
redbaron72
When you find some higher bars,lmk,been looking for some about 2'' higher,but dont want them to be any narrower.
1sickdyna89
Feb 1, 2014 10:25 PM
SA315B
Feb 15, 2009 02:39 PM
the_ogre25
EVO
Nov 27, 2008 10:01 PM
windsoreight
Oct 18, 2008 12:28 PM
StreetGlider56
Mar 30, 2007 05:16 PM
