HID Current Draw??
Old Oct 17, 2008 | 07:11 AM
HawgriderPa's Avatar
HawgriderPa
Default HID Current Draw??
Anyone know the current draw on the Harley HID headlight?
Need to figure out if it's time to switch over to LED brake & turn signals.
Thanx
Old Oct 17, 2008 | 07:16 AM
Superglide 04's Avatar
Superglide 04
HID is less draw than the standard headlight, but the igniter does draw a lot when first turning on the bike.
Old Oct 17, 2008 | 07:18 AM
timvan's Avatar
timvan
exactly... you shouldnt need led's unless your charging system is already taxed
GGC's Avatar
GGC
Thats the way I understand it.
Old Oct 17, 2008 | 10:19 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default a 35 watt
I senn HID's but not Harley type because they have only low beam and they are very expensive. In my unit a 35 watt kit draws 2.7 amps when warmed up but I have measured 2.2 amps fullly functioning. I do not know if this helps you.
Old Oct 17, 2008 | 10:27 AM
Sandcrab's Avatar
Sandcrab
Default Ohm Law
The law is PIE: Power (P) equals Current (I) times Voltage(E).
So if the bulb is 55W and the voltage we know is 12V, then the current is .....
P(55W)=I(?)times E(12V)
55W=12(I)
I=55W/12V
I=4.58 Amps. Simple
Old Oct 17, 2008 | 12:02 PM
HawgriderPa
Thanks guys..
GGC - Nice - you're one glow rail up on me!
FastHarley.. it's not a question of me changing to an HID, I already have the harley unit on the bike - it's got seperate reflectors for high and low beam.
Sandcrab - that law doesn't give me the answer for the HID system, since there's no wattage listed for the bulb. There's a ballast and an ignitor for the xenon tube.... I was looking for the current draw of the ballast.
I'm going to switch the running/turnsignals over to LED, since I added the 50 watt driving lights for nighttime - the ol night vision isn't what it used to be!
Old Oct 17, 2008 | 12:59 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by HawgriderPa
Thanks guys..
Please re-read the post. I answered the question by saying mine unit draws 35 watts @ 2.7 amps. I do not know what HD has for a system or if it is the usual 2.7amp 35 watt system common in HID. That is the answer you asked.
Wakko47
EVO
13
Feb 21, 2013 04:03 AM
Neenjah
Jun 16, 2012 09:02 AM
sloboy
Mar 7, 2011 08:53 PM
jcallesano
Aug 5, 2010 01:56 PM
WideBoy04
Apr 18, 2010 12:20 PM
