Coupla questions.....
Old Apr 2, 2006 | 01:56 PM
ultrared's Avatar
ultrared
Default Coupla questions.....
Before I get flamed...I have searched this, and tried the results, to no avail:
Balance point for red craftsman jack...tried placing rear pad just forward of channel, but no luck. Do I need to go in the channel?
Also, all of my bolts holding my slip-ons are rusted...only on the right side. Is this normal???? Left side are fine...
Old Apr 2, 2006 | 02:55 PM
bountyhunter's Avatar
bountyhunter
Default RE: Coupla questions.....
I set rear pad of my jack right against the front of the crossmember (Craftsman Pro). Yes, it is normal for the hardware on the brutal stock exhaust to corrode. Get out the sawzall, cut those suckers off and get a decent exhaust system on your ride.
Old Apr 2, 2006 | 03:04 PM
liltrk's Avatar
liltrk
I guess my jack is different. I place it INSIDE the channel.
As far as the exhaust hardware, I turn mine under so it is hard to see...have kept the stock pipes, just changed the muffs.
Old Apr 2, 2006 | 04:06 PM
vernh59's Avatar
vernh59
I don't have the Craftsman jack but I put my rear pad under the channel on my RK. No problems with stability so far. Yes the exhaust hardware corrodes.[:'(]
Old Apr 2, 2006 | 09:33 PM
Kess's Avatar
Kess
I run my jack right in the channel and so far so good - I lift the jack slightly and set it up from the right side of the bike - I get good balance- By the way - Even some "decent" exhaust hardware will corrode
Old Apr 2, 2006 | 10:09 PM
ultrared's Avatar
ultrared
Thanks...I will try and get it in the channel and see if that helps. I guess I will try and spin the hardware on my pipes further inward, too...just looks like s@%$ sitting there stickin' out like that. Oh, and Bounty...my stock exhaust is safe and sound...IN MY GARAGE!!! My V&H are very nice, thank you!!!
Y'all have a good one!
Old Apr 2, 2006 | 10:56 PM
Nomad2day's Avatar
Nomad2day
My craftsman pro jack will not fit in the channel. I slid it right up next to it and lift it. Looks like it is off when I start but it goes up fine and is balanced.
Neil
WVDevil
Mar 19, 2016 06:40 PM
jman360
Apr 10, 2013 03:45 PM
WHITEOAKS
Jan 8, 2013 08:20 AM
Tltrump
Exhaust System Topics
Jul 14, 2008 04:07 PM
thomasf59
Mar 27, 2007 09:22 AM
