Need tech help
Old Oct 23, 2008 | 12:34 PM
Big Peter's Avatar
Big Peter
I guess one of the battery cables came loose
when you hit that bump.
Check your cables or circuit brakers.
Peter
Old Oct 23, 2008 | 02:56 PM
thekidnkaren's Avatar
thekidnkaren
Peter
Circuit breakers? Doesn't show any of them in the service manual? Am I missing something?
Old Oct 23, 2008 | 03:20 PM
2008FLHP's Avatar
2008FLHP
do what they've been saying...check wires, fuses, etc...if you can't figure it out take it to McGuiver @ Francisco's tell them Keith w/03 RK sent you...he's good and not too expensive, in fact he'll probably hook it up to the computer for $0, maybe a couple of bucks...if you need help give me shout bro
Old Oct 23, 2008 | 06:43 PM
jon1972s's Avatar
jon1972s
wiring harness ?
Old Oct 24, 2008 | 06:38 AM
smoknwrenchs's Avatar
smoknwrenchs
check the speedo drive sensor at tranny make sure connection is clean and tight ive seen the same thing happen when speedo sensor was bad or poor conn
Old Oct 24, 2008 | 06:49 AM
biz44's Avatar
biz44
Its not that hard to trace the harness from the console back to the fuse block and battery. Bust out the factory service manual, and do some trouble shootin. You know it has got to be a loose wire/ground/fuse/relay or something of that nature because of the way it failed.
Old Oct 24, 2008 | 06:50 AM
BadPiggy's Avatar
BadPiggy
The wiring harness has a ground wire on the right side of the frame, just forward of the VIN stamping. Check that.
The flashing turn signals is a code. You'll need to clear that out.
Old Oct 24, 2008 | 12:38 PM
thekidnkaren
Default Your help greatly appreciated!
Thank you one and all who gave me input or just read this and said, Humm, I think they have it covered. I Traced wires after looking at fuses and grounds, could see no cause for the power loss. Started by pulling fuses and checking them for continuity an low and behold, the assry fuse looked fine but I could get no read on it. I changed that fuse and the speedo and tach came to life. I went though the diag and came up with a code P1356, this doesn't come up on anything I have seen, plus got some PN # come up, any idea where I can look them up? I am thinkin I am gettin into old codes but I am not sure. Thank you all for all your help. Rick
Old Oct 24, 2008 | 12:58 PM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
I just looked in the electrical diag. manual and it shows P1351-P1355 as coil related issues. However, I see no P1356 shown anywhere.
Old Oct 24, 2008 | 01:09 PM
thekidnkaren
I found it listed as a misfire on the rear cylinder, I suspsct I might have gotten some bacd gas when I went north 2 weeks ago. the engine light came on intermittenly and would stay on for 4-6 seconds then go out. When I go what I figured was good premium in it, it slowed down and the bike ran smoother but, the code wasn't cleared
