ABS light on???
Old Oct 23, 2008 | 12:08 PM
Big Twi$t's Avatar
Big Twi$t
Default ABS light on???
I did a search...does not work with just "ABS"..."anti-lock" is useless too.
Anyway, what are some reasons the ABS light is staying on? Manual says an ABS malfunction. My light came on during my commute to work this morning (70 miles one-way).
Thanks.
Old Oct 23, 2008 | 12:21 PM
OregonRoadKing's Avatar
OregonRoadKing
If it stays on while you're at speed, you need to take it in to a dealer and have it checked.
Old Oct 23, 2008 | 01:01 PM
Big Twi$t's Avatar
Big Twi$t
Yes, the manual says that also but, my question is...what are some reasons the light would stay on? I was hoping I could gain some knowledge from someone who has experienced this already. Thanks though.
Old Apr 20, 2009 | 07:15 PM
PaulCB's Avatar
PaulCB
6th Gear
Hey,
Did you ever find out the reason for the light staying on ?
I am in the same situation.....
Thanks,
Paul
Old Apr 20, 2009 | 10:36 PM
SKYCLIMBER's Avatar
SKYCLIMBER
I had the same problem. Found the connector un plugged from when i installed neck covers. Plugged it back up, light went out.
Old Apr 20, 2009 | 11:10 PM
oldbagr's Avatar
oldbagr
Did you add LED lights with a modulator? This can cause problems with the ABS light if the modulator(s) are not compatible with the HD dld electrical system.
Old Apr 21, 2009 | 12:11 AM
Big Twi$t's Avatar
Big Twi$t
Originally Posted by PaulCB
Hey,
Thanks,
Paul
Yes, I did. It was my aftermarket rims, the rear bearing (ABS sensor side) pretty much disintegrated and needed to be replaced. It was a fluke, a bad bearing...the ABS sensor could not take a reading hence why the light was on.
Old Apr 21, 2009 | 11:22 AM
PaulCB's Avatar
PaulCB
6th Gear
thanks for the info. My ultra has only 500 miles on it - I wonder if I have a bad bearing.
I will take her in for a check.
Thanks,
Paul
tinsnips
May 24, 2019 09:31 AM
sixgun95
Oct 22, 2014 01:28 PM
Just Me
Mar 4, 2012 08:02 PM
wulffman
Feb 22, 2010 07:18 PM
tda69
Feb 26, 2009 01:58 PM
