Finally experienced the "wobble"
Old Nov 2, 2008 | 09:32 PM
GT_RoadGlide's Avatar
GT_RoadGlide
Of all the different brands of stabilizers,which can you use with a HD center stand?
Old Nov 4, 2008 | 11:04 AM
Dispatch's Avatar
Dispatch
My question is, which one is the most expensive? Then you can judge the rest by it.
Old Nov 4, 2008 | 11:41 AM
Roadie_Glidin''s Avatar
Roadie_Glidin'
I have been reading through dozens of threads on this "wobble" issue, and I was unaware of it would be like. After reading some posts on here, especially the one here from biz44, I will be putting a stabilizer on this weekend.
I'd rather be proactive instead of having to "scare" myself into getting something done.
There is a group buy for a guy in Oregon who is making these...I will try that one. Here is that thread: HDFORUMS Group Buy, Page 9
~ RIDE SAFE ~
Old Nov 4, 2008 | 12:01 PM
sifularson's Avatar
sifularson
Originally Posted by 6speed
Of all the different brands of stabilizers,which can you use with a Wheel-Dock center stand?
The TWR unit works with the Wheeldock.
You can find it at their site if you are interested.
TWR Missing Link
Old Nov 4, 2008 | 03:39 PM
epsorzano's Avatar
epsorzano
I was curious how did Harley fix the problem with the 09 frame?
Old Nov 4, 2008 | 04:51 PM
lzybt's Avatar
lzybt
Default frame
They made it from much heavier tubing. Fewer welds. A much heavier duty swingarm. It doesn't have the rubbery bushings that cause the problem in the first place. I think they went with some harder plastic on the bushings. The only reason they redesigned it was because they were planning on the triglide trike, and needed a frame that could handle it.
Most people don't realize, if you put a stabilizer on the back, you really should put one on the front of the engine also. I think tri-link is the only one who makes one.
Old Nov 4, 2008 | 05:23 PM
Egldr05's Avatar
Egldr05
The problem is the rear lateral movement. there is no front lateral movement, take care of the rear and the problem is solved.
Thanks for the explanation on the 09 fix. You're the first one who's been able to tell me what has been done to fix it (different bushing material).
Rick
atrox88
Sep 4, 2017 09:33 PM
jp49
Oct 31, 2016 08:33 AM
Gliden
Jul 2, 2012 06:38 PM
danzio
Aug 30, 2011 08:23 PM
..but Ill try 2 try
Apr 3, 2006 10:49 PM
