XM not loud enough
Old Nov 2, 2008 | 07:12 AM
rezi69's Avatar
rezi69
4th Gear
Default XM not loud enough
I reciently had XM installed on my UC and the volume level compared to regular radio and CD is about half. If I switch from FM to XM at same volume It does not have the same base, treble and sound. Anyone else have this problem?
Old Nov 2, 2008 | 08:06 AM
Recon's Avatar
Recon
Something is definately wrong... Volume should be the same. Mine is.
Old Nov 2, 2008 | 08:52 AM
mattman22033's Avatar
mattman22033
I noticed that as well. I just bump the volume up a couple of notches.
Old Nov 2, 2008 | 09:04 AM
Bigredone's Avatar
Bigredone
I think that is normal for the XM on the HK radio. Mine was that way since the day I bought it. Add an amp and your problem will be solved.
Old Nov 2, 2008 | 01:38 PM
rezi69's Avatar
rezi69
4th Gear
any suggestions on a amp? thanks eric
Old Nov 2, 2008 | 01:57 PM
fatboy1017's Avatar
fatboy1017
I had a xm installed in a pick up truck with the same problem. After a week, I took it back in and told them something was wrong. The audio dealer came out and adjusted the line out option, problem solved. It's worth a try.
Old Nov 3, 2008 | 08:59 AM
mrsr71's Avatar
mrsr71
It's adjustable - read the manual that came with it.
shamis
May 31, 2022 01:34 PM
f250hdz
Audio Systems
Jun 10, 2018 12:38 PM
JimmyDee
Oct 10, 2013 12:15 PM
GMRO
Jul 17, 2013 09:21 AM
Ricks07
Oct 27, 2008 11:57 PM
