Front Fork Help
Old Nov 2, 2008 | 06:14 PM
fathogg's Avatar
fathogg
Default Front Fork Help
I just put chrome lowers and Progressive lowering springs to lower it one inch, and heavier oil (20w) on a 2008 Ultra Classic. It is bottoming out and popping on extreme front braking, and when I hit a big bump in the road. The suspension is stiffer which is what I like, but why is it bottoming put so easy?
Old Nov 2, 2008 | 06:33 PM
Plow64's Avatar
Plow64
...because you installed 1" lowering springs....? The suspension has less travel....
Old Nov 2, 2008 | 06:38 PM
BadPiggy's Avatar
BadPiggy
-1" isn't going to make it bottom out.
Did you put the correct amount of oil in the tubes?
You didn't leave your emulators out?
Did you cut your pre-load spacers correctly?
Old Nov 3, 2008 | 07:31 AM
fathogg's Avatar
fathogg
Thanks for the info. I took them apart and had a local shop install the springs and oil. I guess I will take it back to them.
Old Nov 3, 2008 | 09:42 AM
BadPiggy's Avatar
BadPiggy
Wait a sec.
When you re-installed the forks, did you put the black rubber fork stops above or below the lower triple tree?
Regarding taking the forks back...I believe I'd tear into them and have a look myself. Make sure they did their job properly and didn't leave anything out.
Fork jobs are simple. You should be able to do these yourself if you have a manual. Taking the forks off is half the battle.
Old Nov 3, 2008 | 09:58 AM
dougbk's Avatar
dougbk
It sounds like there is not enough pre load on the springs.
Old Nov 3, 2008 | 05:09 PM
fathogg's Avatar
fathogg
I put the fork stops above the tree
rhallman
Apr 27, 2019 08:13 PM
bagger76
Dec 13, 2011 07:42 PM
sdaley6999
Jan 2, 2011 10:37 PM
dmbeveryday
Nov 15, 2010 09:21 PM
1sportytrike
Feb 16, 2007 12:20 PM
