never mind a new bolt I busted a rod and it will not break again.
my wife is more than 100 lbs but the force from that little step up, on one foot board was just too much
I have seen al least 3 other threads on this, not Kury, but HD, dealer installed. They probably need to go to next-size-up bolt. It is clear that there is too much leverage for the current bolt.
Don't count on it. The MoCo went with 3/8-16 bolts on the '09 rider footboard brackets and that is a step down from the 1/2-13 bolt on '08 and older models.
This inexcusible failure is potentially life threatening. Is there a "warning" included with the part? Has this been brought to the MOCO's attention?
(edit)
OK............I just looked at the part. Yes, there would be a huge strain on the bolt if the passengers entire body weight were placed on the board. There should definitly be a posted warning on the part.
I'm going to keep a close eye on this, since I have these on my 08 Ultra. I thought I saw on another thread that a grade-8 bolt of that size should be rated to hold several thousand pounds, so maybe some bad bolts out there? I've also heard that over-torquing might be part of the problem, but another thing I've noticed on my bike, with the passenger floorboards mounted straight up like in my sig-picture they ride steady and solid, but about a month ago I move them a notch forward, so the mount is at about the 1:00 o'clock position and when folded up there is a constant vibration in them at highway speed....so maybe the mounting position has something to do with it?
A looong time ago I put polished stainless bolts on my floor boards. Never had a problem with breaking a bolt. Stainless is only a grade 2 I think. Could it be it was a defective Bolt?-Al
Stock MoCo bolt is a stainless steel bolt stamped H-D GRD 8. Could have been over torqued.
I use the #8 bolts ( black carbon alloy steel) fr Lowes and haven't had a issue but OL only has gone on two trips 3k miles then I take them off, has anyone broke one of these? If the HD ones are SS? they could be overtorqued which is probable the problem. I just google stainless steel #8 stength and bassically they are equal to a grade 5 w 125k PSI vs. grade 8 150k psi. One article fr ebay talked about using anti seize but reducing the tq fr 20ft/lbs by 20% so that's not much. I think the case harden #8 is the solution but the MOCO will never admit this. Again has anyone broke a grade #8 (black) bolt?
