New Touring Stabilizer
Old Nov 21, 2008 | 10:08 AM
  #71
AaronOregon's Avatar
AaronOregon
Former Sponsor
Originally Posted by Yachtman
I'll leave it alone now, promise.
I knew you couldn't do it! You're not the type.
Old Nov 21, 2008 | 10:11 AM
  #72
Yachtman's Avatar
Yachtman
Hey Aaron, I can't answer someones question?
Old Nov 21, 2008 | 10:15 AM
  #73
MODCOBRA's Avatar
MODCOBRA
[QUOTE
Ben,
I'll remove the 'studs' just for you. I don't want you to be upset.[/QUOTE]
If your 'studs' are anything like mine, on my Mustang, you won't have to remove them. They have a tendency to come off all by themselves. I have lost two....backrest and seat.
Mustang did, however, send me a repair kit (3 studs) glue and instructions for free.
Old Nov 21, 2008 | 10:20 AM
  #74
Yachtman's Avatar
Yachtman
It seems Mustang has decent customer service. Didn't the studs they sent you have the pin type or staple pins that go through the material. I didn't know there even/ever was a glue on type! How did they come off? I try to not let my pants drag across the studs, which is a bitch sometimes with these old hips.
Old Nov 21, 2008 | 10:38 AM
  #75
2011 Road Glide Ultra's Avatar
Originally Posted by AaronOregon
05 Deluxe, Yachtman could not be further from wrong! Aaron
Could not be further from wrong - isn't that saying he's right? Just sayin'......
Guys, all the braces on the market appear to have satisfied customers. They all perform the same basic function. They differ in materials, design, and finish. I have yet to hear of anyone having a failure of any unit, saying they didn't work, or complaining about ground clearance. If you feel the need to get one, look at what you are getting and make a choice. If you don't feel the need to get one, ride on with what you have.
Old Nov 21, 2008 | 12:14 PM
  #76
MODCOBRA's Avatar
MODCOBRA
They sent me the staple type that goes thru the material. You put a dab of glue on the metal, push the 'staples' thru the existing holes from the old stud, and 'try' to bend the staples to hold it in place.
I am sure that my old legs brushed the studs as I was getting on/off.
Old Nov 21, 2008 | 12:56 PM
  #77
asatguy's Avatar
asatguy
Aaron,
Got the brace a couple of weeks back. It took me a few days to sand/prime & paint it. Also received the new shorter right-side dogbone bolt - thanks! Installed the brace last Sunday. It took me a bit longer, only due to my own wrenching limitations, but I got it done. Leaving town, so haven't been able to ride it yet. Looking forward to it though.
I personally also like the idea of having something similar to a "skid-plate" under the tranny pan, JMO.
Thanks again!
Old Nov 21, 2008 | 01:12 PM
  #78
jdman's Avatar
jdman
One would think if Harley thought it was bad enough they would have already addressed this by now.
Old Nov 21, 2008 | 01:24 PM
  #79
They did - the '09s.
Old Nov 21, 2008 | 01:30 PM
  #80
96 Ultra's Avatar
96 Ultra
Please understand I'm not trying to start any controversy, but I'm really trying to understand.
One thing I find funny about all the different stabilizers, is where does it connect to the swing arm to keep the rear tire stable ?
Granted I'm not an engineer, but common sense tells me that a product must connect to the swing arm in order to stabilize it.. right ?
Engine is mounted to bike frame.... tranny is mounted to engine... stabilizer is mounted to tranny and frame.
I mean, you can stabilize the engine all you want, but the rear swing arm is still floating around. Wouldn't it make more sense to design a swing arm that used bearings instead of rubber bushings ?
And if these stabilizers make such a difference... why doesn't Harley incorporate this design in the bikes suspension... I mean I'm sure they they wouldn't intentionally produce an unsafe vehicle, right ?
