Accessory Connection
Old Nov 10, 2008 | 08:27 AM
Harleypingman's Avatar
Harleypingman
The accessory connector will be a four-wire Deutsch connector--the back of your Service Manual has pics of it and the other connectors HD uses. As mentioned, your HD store can sell you the corresponding male Deutsch connector and pins/sockets for the wire ends.
You don't mention the amperage of the auxilary lights you are using. HD fog lamps and Motolights use a relay--the switch controls the relay--not the power to the lights. HD passing lamps, being lower amperage, don't use a relay.
The accessory connector has a ground wire, a brake light circuit wire, an ignition/run light circuit, and an accessory circuit wire. Your service manual will help you identify which wire goes to each circuit.
Old Nov 10, 2008 | 08:52 AM
rocknrod's Avatar
rocknrod
The one with the cover on it:
Talldog
Electrical/Lighting/Alarm
Mar 13, 2017 08:05 AM
motrhd
Mar 25, 2011 03:44 PM
testifer
Mar 22, 2009 10:38 PM
Hrlyrider
Dec 28, 2008 09:17 PM
roadking1893
May 28, 2008 09:30 PM
